    Solved Print is smaller than model in STL file
    213
    • andreic
      andreic last edited by
      Hi, everyone,
      So, I recently updated to 3.3 and just now to 3.4, and after the 3.3 and I encountered this problem; I print the regular XYZ test cube 20x20x20mm and the thing is that it comes out 16x16x16x20.
      Thought it was the steppers and that maybe something got mixed in the update and I reconfigured everything using the RepRap config tool but still no deal. Any ideas on why this is happening?
      • I reconfigured it (reprap tool)
      • changed 3 filament spools just to test that it wasn't that
      • tried cura and slic3r
      I'm running a Duet 2 wifi on an Anycubic Kossel Linear Plus with a bondtech bmg extruder. Changed the stock rods to 286mm ones. Custom effector.
      I repeat. This config worked 2 days ago on 3.3, no problems. Then after a recalibration, i saved the new settings I got from m665 and m666 and that's about it.
      here is my config
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Mar 17 2022 03:15:28 GMT+0200 (Eastern European Standard Time)
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"Kossel"                                         ; set printer name
      M665 R120 L286 B115 H271.935                           ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-1.17 Y0.20 Z0.97                                ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                                ; enable network
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S1                                             ; physical drive 0 goes forwards
      M569 P1 S1                                             ; physical drive 1 goes forwards
      M569 P2 S1                                             ; physical drive 2 goes forwards
      M569 P3 S1                                             ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                       ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X80 Y80 Z80 E411.83                                ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00               ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30                        ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                ; Set idle timeout
      M208 Z0 S1                                             ; set minimum Z
      M574 X2 S1 P"xstop"                                    ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                    ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                                    ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      M558 P0 C"^e0stop" H5 F120 T6000                       ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z16                                     ; set Z probe trigger value, offset and trigger height
      M557 R85 S20                                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as PT1000 on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.442 K0.466:0.000 D8.33 E1.35 S1.00 B0       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R1.152 K0.340:0.000 D8.10 E1.35 S1.00 B0 V12.3 ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                      ; set fan 1 value. Thermostatic control is turned on
      M563 P1 D0 H1 F0                                       ; define tool 1
      G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
      G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
      Cheers
      zabana 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk last edited by
        @andreic you either need 100 steps per mm or something strange is going on with your M665.
        Can you post your config override?
        Do you know how many teeth are on your motor pulleys?
        andreic 1 Reply Last reply Reply Quote 0
        • andreic
          andreic @jay_s_uk last edited by
          @jay_s_uk
          Yep...forgot to mention I also tried configuring for 100 on steppers, but that just messes everything else when it comes to measurements, and wasn't able to get it to print like this. And like I said printer worked for at least 1 full year with those settings without problems.
          this is the config.bak
          M906 X1500 Y1500 Z1500 E800 I30                        ; set motor currents (mA) and motor idle factor in per cent
          jay_s_uk 1 Reply Last reply Reply Quote 0
          • jay_s_uk
            jay_s_uk @andreic last edited by
            @andreic config-override not config.bak
            • andreic
              @jay_s_uk Sorry. Misread. there is no config override.
              • jay_s_uk
                @andreic ah, just assumed you'd have one after running G32 and saving the settings.
                Can you post an example gcode file? might have to change the file extension
                • andreic
                  @jay_s_uk
                  Sure. Here is the cube AKLP_xyzCalibration_cube.txt
                  • jay_s_uk
                    @andreic that gcode looks correct.
                    do you have your old config?
                    • andreic
                      @jay_s_uk
                      unfortunately, I don't have the old one that worked but I'm pretty sure that it wasn't different. 😢
                      • jay_s_uk
                        @andreic what type of rods do you have?
                        • andreic
                          @jay_s_uk
                          carbon rods + ball links 286 mm
                          • zabana
                            zabana @andreic last edited by
                            @andreic did you tried to reinstall the previous version so you can check if it is something related to the fw or the config file?
                            • andreic
                              andreic @zabana last edited by
                              @zabana
                              Yeh...I finally gave up trying to fix it and reset everything and reinstalled everything from scratch (software-wise)... works fine now.
                              Thanks for your suggestions guys. Cheers
                              • Topic has been marked as a question  Phaedrux Phaedrux
                              • Topic has been marked as solved  Phaedrux Phaedrux
