    1XD brake control without signal
    • p8blrundefined
      p8blr
      I'm reading the guide here on how to add a brake. I'm using an external power-off brake that simply needs 24V (300ma) and I want to wire it to out_0 on the 1XD. The example in the guide shows an M950 and M581 to control the output by a control signal from the motor, but I don't have that. What should I do so that the brake is powered (motor free) when that motor is enabled, and not powered (motor braking) when it is disabled?
      Thanks.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @p8blr
        @p8blr what do you mean you don't have those gcodes?
        What firmware are you running on both boards? Maybe a bit more info about your setup
          dc42 administrators @p8blr
          @p8blr please upgrade to firmware 3.4.0 and use the M569.7 command instead to control the brake, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5697-configure-motor-brake-port.
          p8blrundefined 1 Reply Last reply Reply Quote 1
          • p8blrundefined
            p8blr @dc42
            @dc42 Perfect! Thank you so much!
