    REST Api Questions
    • markz
      markz last edited by markz
      Hi, I've just upgraded to 3.4.0, which may be relevant.
      I'm trying to update an old application that uses the REST Api and a few things:
      1. The REST Api doc doesn't seem to be on the new doc site
      2. Per the above, the search on the new doc site seems very bad. Is it really unable to search for more than one word? The doc seems great, but.
      3. I have 3 installations (Duet2, 6HC, 6HC+SBC). For the non-SBC's I can type http://devip/rr_status and get back a json status in my browser. On the third (the 6HC+SBC) I get a page not found (404) error so no rest api?
      I looked at the (old) C# code I have to use the REST Api and it had commented out code for an authorization token so maybe I did something to the CNC (Duet2). The current/old RESTful software is working fine on that machine with no token.
      The existing api doc discusses tokens but imho it's impenetrable.
      I honestly don't care now since the +SBC system is the only one I'll never use this software on but I'd kind of like to know the root cause in case it matters some day.
      Thanks.
      Sindarius 1 Reply Last reply Reply Quote 0
      • Sindarius
        Sindarius @markz last edited by
        @markz with the SBC has a different set of endpoints. You can find more information here https://github.com/Duet3D/DuetSoftwareFramework/wiki/REST-API
        markz 2 Replies Last reply Reply Quote 0
        • markz
          markz @Sindarius last edited by markz
          @sindarius Thanks. That's really nice doc for the SBC version. A link to the non-sbc version would be nice here since I'm not clear on the differences. Will I need two different sets of code to talk to the SBC/non-SBC models? I have both here that I use and can test with.
          Meanwhile, I looked at the firmware repository for 3.4.0 and it appears to not be sending back CORS allow headers so I'm having cross domain issues from my application. When I use, for example,
          curl http://duetcnc.local/rr_status -v
          it returns no CORS headers and this is a Duet2.
          I know this is in the weeds but help?
          Mark
          chrishamm 1 Reply Last reply Reply Quote 0
          • markz
            @sindarius I went around and around and at least on my application all I needed was Access-Control-Allow-Origin: * for the rest api at least from private->private.
            From public->private I just had problems and although the spec discusses Access-Control-Allow-Private-Network (response) and Access-Control-Request-Private-Network (request) in preflight that didn't seem to work for me in a public url.
            • Sindarius
              Sindarius @markz last edited by Sindarius
              @markz you can adjust cors by using M586. You can open it up with M586 Cā€*ā€
              You can see a list of the standalone GET requests here https://github.com/Duet3D/DuetWebControl/blob/legacy/README.md
              markz 1 Reply Last reply Reply Quote 1
              • markz
                @sindarius You're officially my favorite person today. I spent a day diagnosing this and trying to find a workaround.
                • chrishamm
                  chrishamm administrators @markz last edited by
                  @markz You can find the docs for the RRF HTTP API here: https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests
                  Duet software engineer
