    Duet3-1LC accelerometer doesn't work in 3.4 (M956)
    Firmware developers
    593
    • Megamannenundefined
      Megamannen
      Works in 3.3.0, doesn't work in 3.4.0
      M955 I14 P121.0
      G91
      G1 X-50
      G4 S2
      M956 P121.0 S1000 A0
      G4 P10
      G1 X50 F20000
      G90
      Error: Failed to start accelerometer data collection: INT1 error
        jay_s_uk @Megamannen
        @megamannen can you post an output of M122 B121?
        Megamannenundefined 1 Reply Last reply Reply Quote 0
          Megamannen @jay_s_uk
          M122 B121
          Diagnostics for board 121:
          Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
          All averaging filters OK
          Never used RAM 2624, free system stack 88 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.4%,111) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,27) TMC(notifyWait,3.0%,67) MAIN(running,91.7%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
          Last reset 00:06:07 ago, cause: software
          Last software reset data not available
          Driver 0: pos 0, 690.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 48625, writes 5, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter -5/6, peak Rx sync delay 211, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.4, current 24.4, max 24.4
          MCU temperature: min 38.2C, current 38.5C, max 38.6C
          Last sensors broadcast 0x00000002 found 1 78 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 7246, send timeouts 0, received 3270, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          Accelerometer: LIS3DH, status: 00, INT1 error!
          I2C bus errors 0, naks 0, other errors 0
            @megamannen does it have a diode on the underside of the board need the edge? It's been added after manufacture so should be easy to spot
              @jay_s_uk I don't think so, didn't see any components on the underside. Which edge? It's currently mounted and a bit difficult to look at the underside.
              But how does it explain why it works in 3.3 and not in 3.4?
              jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                @megamannen it's on the bottom left of this image
                It has something to do with the INT pin but I don't know why it would work with 3.3 and not with 3.4
                  dc42 administrators @Megamannen
                  @megamannen are you certain that the accelerometer is able to collect data using RRF 3.3? In RRF 3.4 we added an extra check to help diagnose a situation in which the accelerometer appeared to be working but didn't collect data when the interrupt signal was missing.
                    @jay_s_uk I will double check, but I got a file with numbers in it, let me get back to you with a file
                      Megamannen @dc42
                      I got a file with numbers in v3.3, but it feels like it ends badly
                      (whole file: x.csv )
                      Sample,X,Y,Z
                      0,0.00,0.09,1.00
                      1,0.00,0.09,1.00
                      2,-0.02,0.02,0.98
                      3,-0.02,0.02,0.98
                      4,-0.02,0.02,0.98
                      5,-0.02,0.02,0.98
                      6,-0.06,0.08,1.00
                      661,0.11,0.03,1.09
                      662,0.11,0.03,1.09
                      663,0.11,0.03,1.09
                      664,0.08,0.22,1.02
                      Received mismatched data
                      @jay_s_uk
                      I think I identified the correct corner, it was easy to photograph for me. It's missing the diode, right?
                        @megamannen looks like it's missing. One for @Phaedrux or @dc42
                        When and where did you buy it?
                          @jay_s_uk
                          Bought it at 2022-03-09 from your official reseller https://hobby-store.pl/
                            @megamannen is it a revision 1.1 tool board? If so then I'm sorry, it is indeed missing the diode, which provokes the error message when you run RRF 3.4 on it. Please email warranty@duet3d.com and include a link to this thread.
                              Megamannen @dc42
                              Yeah, v1.1
                              No problem, you guys found the issue in no-time, will contact support ☎
