I just re-soldered some pins
Hi Duet users, I have been looking at the pins on the sd card holder and the wifi module for awhile now. I finally got out my surface mount/micro soldring iron. Put some kapton tape down around these areas. Fluxed those pins, Put on my magnifying visor, Turned my solder iron up to 500 degrees. 420 at tip. And re-soldered all those pins. Now when I test this loading procedure it is so much better. The pin with the poorest solder connection was the ground pin. On the wifi module. I truely believe this made a huge improvement. Should have done this months ago. Anywhoo Peace out. p.s. Thingiverse files still load very inconsistently. And I have also read all about this, and their 5 second delay. Or messy files. With way to many vertices. Overall the way this Duet 2 wifi works is so amazing. Just as long as it loads my files. Have fun out there.
I assume this is in resolution to this thread?
https://forum.duet3d.com/topic/27836/duet-2-wifi-struggles-to-load-my-files/3?_=1647892453313
