    Feature request: Min Power for Velocity Ramping
    Laser Cutters
    • rabbit
      rabbit last edited by rabbit
      Meanwhile my co2 laser is working. Thanks for the great support.
      I noticed that the laserpower at a contour with many small lines is much lower than with straight lines (see the picture below - the square was cut with the same laserpower as the deer ).
      I think a min Power setting for velocity ramping should fix this.
      Best,
      gloomyandy 1 Reply Last reply Reply Quote 0
      • gloomyandy
        gloomyandy @rabbit last edited by
        @rabbit What version of RRF did you use for that?
        rabbit 1 Reply Last reply Reply Quote 0
        • rabbit
          rabbit @gloomyandy last edited by
          @gloomyandy I use the latest 3.4.0 release on a Duet 3 with SBC
            dc42 administrators @rabbit last edited by
            @rabbit if the speed is slowing down on curves, try increasing your X and Y jerk settings (M566).
            • rabbit
              rabbit @dc42 last edited by
              Since the working area is quite large (1500mm x 600mm) I can't go above 300 mm/min jerk without having excesive vibrations.
