    Solved Duet 3 Mini 5+ Wifi problem
    Duet Web Control
    112
    • asimitabi
      asimitabi last edited by asimitabi
      Hello together!
      I just built a new RatRig Printer with Duet 3 Mini 5+ Wifi with external antenna.
      I have packed on the SD card the new config-file and the other files. Since the printer currently has no display to enter the wifi data, I wrote the following in the config file:
      M587 S"WLAN-NAME" P"WLAN-PASSWORD" I192.168.1.15
      M552 S1 P"WLAN-NAME"
      I assumed that the printer now connects to the wifi on first startup and I can access the DWC in the browser using the fixed IP address.
      Unfortunately nothing happens, does anyone have an idea what the problem could be?
      Thanks a lot!
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @asimitabi last edited by
        @asimitabi you need M552 S0 before you try and send wifi details
        asimitabi 1 Reply Last reply Reply Quote 0
        • asimitabi
          asimitabi @jay_s_uk last edited by
          @jay_s_uk thanks for the fast reply!
          I now did:
          M552 S0
          but if I put in the IP in my browser nothing happens...
          jay_s_uk Stephen6309 2 Replies Last reply Reply Quote 0
          • jay_s_uk
            @asimitabi why not just send it over USB to get going?
            • asimitabi
              @jay_s_uk The computer is a bit away from the machine and the machine is very heavy as its 500x500x750mm with enclosure. I cant bring them together here.
              I thought this must work or do I need a specific IP?
              • Stephen6309
                Stephen6309 @asimitabi last edited by
                @asimitabi Is the board actually on that IP address? Use an IP scanner to see, I use the free Advanced IP Scanner in Windows.
                • asimitabi
                  asimitabi @Stephen6309 last edited by
                  @stephen6309 Thank you I now tried to remove the IP-adress so it will find its own but it seems like the board is not connected to the wifi as the IP-scanner cant find the board
                  Stephen6309 1 Reply Last reply Reply Quote 0
                  • Stephen6309
                    @asimitabi In YAT, sending M587 with no parameters shows the saved wifi networks in the wifi chip.
                    This has info on connecting wifi:
                    https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                    • asimitabi
                      asimitabi @Stephen6309 last edited by asimitabi
                      @stephen6309 yes I know but I cant connect the computer right now via cable as its too far away...
                      If there isnt another option I will drive home and pick up my laptop to do it via cable. I just thought this must work normally
                      • Stephen6309
                        @asimitabi If you have a paneldue, it can be done via it's console.
                        • asimitabi
                          I dont have the paneldue here but it works now, I took my laptop from home and made it normally via YAT.
                          Thank you guys for the fast answers! 🙂
                          Regards
                          • Topic has been marked as a question  Phaedrux Phaedrux
                          • Topic has been marked as solved  Phaedrux Phaedrux
