    Convert PT100 Daughter Board to PT1000?
    626
    • Topherundefined
      Topher
      I was looking at the documentation for the MAX31865 used in the PT100 daughter board. I have long leads on my sensors so i think 100ohm sensors might be problematic for my application and also, I have lots of 1k sensors. Could I change out R1 and R3, and R2 and R4 with the appropriate resistors to compensate for the 1k sensor? I think I could leave the filter caps larger and it should be fine as I dont need super fast readings.
      Stephen6309undefined achrnundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Topher
        @leckietech PT1000 connect as thermisters.
        • zaptaundefined
          zapta
          What duet board are you using? Generally speaking, PT1000 doesn't require a daughter board and can connect directly to the duet. You do need to tell the duet though that this is a PT100.
          As for using the MAX31865 for PT1000, I wonder if it will be significantly more accurate than the duet alone.
          https://www.digikey.com/en/datasheets/maxim-integrated/maxim-integrated-max31865
          mendenmhundefined Topherundefined 2 Replies Last reply Reply Quote 0
          • mendenmhundefined
            mendenmh @zapta
            @zapta I would strongly expect this to be more accurate than the A/D input of the Duet. It won't suffer channel-multiplexing induced charge injection, and other sources of error in multiplexed A/D system. It very likely uses a precision constant-current source to drive the sensor, so the accuracy of the output isn't affected in the same way it is with the output in a bridge circuit.
            @LeckieTech It seems as if there is no reason switching resistors and capacitors wouldn't work. The chip is designed to do this.
            • achrnundefined
              achrn @Topher
              @leckietech said in Convert PT100 Daughter Board to PT1000?:
              Long leads is what four-wire connections are for. The four wire connection eliminates the error due to lead resistance (provided all four wires are the same and at the same temperature) so the lead-length-induced error is only that due to the portion between the point where the leads come together and the sensor element - which is normally (or should be) very short.
              Topherundefined 1 Reply Last reply Reply Quote 1
                dc42 administrators @Topher
                @leckietech yes that should work. I'm not sure whether you could get away with not changing the capacitor, because I have a feeling that the MAX31865 doesn't supply voltage to the sensor continuously.
                To reiterate the comments made by others:
                1. You can eliminate wiring resistance from the measurement by using a 4-wire connection (even if the sensor itself is 2 wire);
                2. You can connect PT1000 sensors directly to thermistor inputs, although accuracy may not be as great as when using the MAX31865.
                Topherundefined 1 Reply Last reply Reply Quote 0
                • Topherundefined
                  Topher @achrn
                  @achrn I have a 1mm pitch 300mm long FFC driving my hotend. The wiring path for the sensor has to travel through this.
                  mendenmhundefined 1 Reply Last reply Reply Quote 0
                  • Topherundefined
                    Topher @zapta
                    @zapta said in Convert PT100 Daughter Board to PT1000?:
                    im using Duet 3 mini. I need 2 additional sensors for my build. One for the cooling fan air intake and one on the LDO motor feeder.
                    • Topherundefined
                      Topher @dc42
                      @dc42 Thank you, this is what i needed to know to add additional sensors to my printers.
                      • mendenmhundefined
                        mendenmh @Topher
                        @leckietech do you have enough conductors to put a ground on each side of the PT100/PT1000 wiring? It will help hugely on the noise floor.
