    LIS3DH accelerometer to duet 3 mini 5+ wifi
    488
    • RatRig0331undefined
      RatRig0331
      How do I wire in a LIS3DH accelerometer to my duet 3 mini 5+ wifi? And what needs to be done on the firmware side to get input shaping going? Thank you in advance
      • oliofundefined
        oliof
        • Start reading here for physical connection:
          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer
        • Look here for configuration
          https://docs.duet3d.com/User_manual/Reference/Gcodes#m955-configure-accelerometer
        • Use the inputshaping plugin to get visuals
          https://forum.duet3d.com/topic/26447/inputshaping-plugin-0-2-0-pre8-2-released?_=1648338213765
        RatRig0331undefined 1 Reply Last reply Reply Quote 1
          RatRig0331 @oliof
          @oliof yes I’ve read those and there still not making sense to me of what wire goes to what pin on the duet 3. The second pic of the purple accelerometer is the chip I’m using but the two row plug dosn’t really show well what the connections are
          dhusoloundefined 1 Reply Last reply Reply Quote 0
          • dhusoloundefined
            dhusolo @RatRig0331
            @ratrig0331 It tells you what pin on the accelerometer plugs into what pin on the Duet 3 Mini.
            RatRig0331undefined 1 Reply Last reply Reply Quote 2
              RatRig0331 @dhusolo
              @dhusolo I think I have everything wired in right but when I do a m955 it says accelerometer not found
              • dhusoloundefined
                dhusolo @RatRig0331
                @ratrig0331 You need to define it before you can call it back with M955
                RatRig0331undefined 2 Replies Last reply Reply Quote 0
                  RatRig0331 @dhusolo
                  @dhusolo I did a m955p0
                    RatRig0331 @dhusolo
                    @dhusolo and a M955 P0 C"io3.out+io3.in"
