    Duet2 WiFi diag LED stays RED
    • create.at.hwbdesign.comundefined
      After a firmware update to 3.4 my Duet is not able to connect to WiFi.
      Cleared firmware after disconnecting the wiring and power.
      Direct connection via USB Duet is visible for Bossa. Updated the firmware.
      Result: connection disappears.
      Retried more times. After deleting the firmware connection with Bossa and YAT is possible after writing the firmware no connection possible.
      Faulty board?
      Faulty user?
        If you apply the firmware with bossa, are you then able to connect via YAT?
        How did you initially update to 3.4? I'm thinking that the wifi server firmware update didn't apply.
        If you can get YAT up, you can send M997 S1 to reflash the wifi module, which may get it going again if that was the issue.
        Otherwise, have a go at this guide and see how far you get.
        https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
        create.at.hwbdesign.comundefined 1 Reply Last reply Reply Quote 0
          create.at.hwbdesign.com @Phaedrux
          @phaedrux Only after stepdown to 2.05.1 then WiFi is active again.
          Reinstalling 3.4 same problem. It's a board version 1.05.
          3.3 work fine?!?
          Diag result in fileDiag.txt
            droftarts administrators @create.at.hwbdesign.com
            @create-at-hwbdesign-com I'd guess you are using the wrong 3.4 firmware file, or the firmware file is corrupted. Try downloading it again.
              If you skip directly to 3.4 via Bossa, make sure you also manually update the DWC files in the WWW folder on the SD card. This may explain why you can't reach the web page.
