    BLTouch on Duet 3 Expansion XD1
    • rabbitundefined
      rabbit
      Is it possible to connect the bl touch to the xd1 expansion board, or is it not supported?
      Best,
        You mean the 1XD?
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1XD
        Or the 1LC?
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC
        rabbitundefined 1 Reply Last reply Reply Quote 0
        • rabbitundefined
          rabbit @Phaedrux
          @phaedrux yes I mean the 1xd expansion board
            dc42 administrators @rabbit
            @rabbit yes you should be able to use IO0 or IO2 to support a BLTouch because both support PWM on the output pin. It's probably never been tested, but it uses the same code as the tool board, which definitely supports BLTouch.
            • rabbitundefined
              rabbit @dc42
              @dc42 Hi,
              I had a typo in my config. now it works fine.
              Thanks for the great support.
