    Setting up Duet 2 for Railcore 3D Printer
    Firmware installation
    137
    • MKMachining 0
      MKMachining 0 last edited by
      Recently a board for one of our printers was fried and needed to be replaced. The SD card seemed to take the most damage so I could not recover the old files.
      I have now set up the new board exactly how the old one was (printer worked fine for years before the failure). I then went through the setup process provided for the Duet2Wifi. Finally i installed the configuration provided by railcore. Whenever I turn on the machine it has errors.
      The homing gcodes do not work either due to "G28 Error: Failed to enable endstops"
      oliof 1 Reply Last reply Reply Quote 0
      • oliof
        oliof @MKMachining 0 last edited by
        @mkmachining-0 could be that the railcore config is for RepRapFirmware 3 and the duet board is still running RepRapFirmware 2.
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        MKMachining 0 1 Reply Last reply Reply Quote 1
          Please post your config.g and the results of M122 and M98 P"config.g"
          I think that will confirm what oliof says.
          • MKMachining 0
            MKMachining 0 last edited by MKMachining 0
            This post is deleted!
            • MKMachining 0
              MKMachining 0 @oliof last edited by
              @oliof M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9P6B2-NJ4S4-6J1FA-3S86L-KB1LL
              Used output buffers: 1 of 24 (17 max)
              Static ram: 23868
              Dynamic ram: 73292 of which 252 recycled
              Never used RAM 14668, free system stack 184 words
              Tasks: NETWORK(ready,13.0%,258) HEAT(suspended,0.0%,387) MAIN(running,86.9%,431) IDLE(ready,0.0%,30), total 100.0%
              Owned mutexes: WiFi(NETWORK) USB(MAIN)
              Last reset 00:03:49 ago, cause: reset button or watchdog
              Last software reset details not available
              Error status: 0x08
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 36.3, current 36.3, max 36.3
              Supply voltage: min 1.9, current 1.9, max 1.9, under voltage events: 1, over voltage events: 0, power good: no
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a
              Driver 1: standstill, SG min n/a
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2022-03-30 10:04:56
              Slowest loop: 4.69ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.1ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is ready with "M122" in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === Network ===
              Slowest loop: 199.91ms; fastest: 0.07ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                Failed messages: pending 0, notready 0, noresp 7
                WiFi firmware version 1.26
                WiFi MAC address e0:98:06:22:e6:1f
                WiFi Vcc 3.39, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 26776
                WiFi IP address 192.168.0.177
                WiFi signal strength -62dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                ok
              M98 P"config.g"
              Error: Pin name needed for switch-type endstop on X axis
              Error: M305 has been replaced by M308 and M950 in RepRapFirmware 3
              Error: Heater 0 not found
              Error: Heater 1 not found
              Error: Heater 1 does not exist
              Error: Fan number 0 not found
              Error: Fan number 1 not found
              Error: Fan number 2 not found
              Error: Heater 3 not found
              Error: Missing Z probe pin name(s)
              Error: Invalid Z probe index
              ok
              jay_s_uk 1 Reply Last reply Reply Quote 0
              • jay_s_uk
                jay_s_uk @MKMachining 0 last edited by
                @mkmachining-0 you're trying to use a config for RRF2 with RRF3. Either see if one is available for your printer or generate a new one using the config tool
                • MKMachining 0
                  MKMachining 0 @jay_s_uk last edited by
                  @jay_s_uk I believe the duet 2 came as 3.1.1 and had errors so I updated it. If there is a way should I downgrade to RRF2? Is there a recommended version you have?
                  • jay_s_uk
                    @mkmachining-0 i wouldn't recommend downgrading to RRF2.
                    There are config files for a railcore here for RRF3 https://railcore.org/software/
                    • MKMachining 0
                      @jay_s_uk Its not having those errors anymore, however when i try to home the machine it gets an error for "Driver 2 error: phase A short to ground" then "driver 2 is overheated"
                      • jay_s_uk
                        @mkmachining-0 that doesn't sound good. I would check your wiring
                        • MKMachining 0
                          @jay_s_uk The wiring is the same as the one before that had no issue. I'll make another post for this issue.
                          Thank you for your help!
