    internal precision and external pressure DueT WiFi
    My Duet controlled machine
    123
    • paolozampini1973
      paolozampini1973 last edited by
      Hello Someone can tell me why if I print a circle WITH 30MM INTERNAL HOLE AND 38MM EXTERNAL HOLE, the internal precision HAS an error of 0.03 Maximum AND IT'S OK FOR ME
      instead EXTERNAL error of 0.5 THAT IS NOT GOOD I think it is not a problem of printer precision because otherwise the internal part would not be so precise AND THE EXTERNAL PART there is a strong difference
      the prints are all the same THEY ARE PERFECTLY THE SAME EVEN ON MULTIPLE PRINTS errors is repetitive There is no difference even the vertical line YES VERY LITTLE NOTICE
      • deckingman
        deckingman @paolozampini1973 last edited by
        @paolozampini1973 Most likely a slicer issue or the original STL file has too few segments. Because 3D printed holes and circles are made up of multiple straight line segments, they will never be truly accurate in diameter. It's simply a fact which must be born in mind when designing parts for 3D printing and due allowance needs to be made at the design stage.
        paolozampini1973 1 Reply Last reply Reply Quote 0
        • paolozampini1973
          paolozampini1973 @deckingman last edited by
          Can anyone tell me if I can create a CURA print profile from a lost gcode
            Phaedrux Moderator @paolozampini1973 last edited by
            @paolozampini1973 said in internal precision and external pressure DueT WiFi:
            Maybe. If you saved it as a .3MF file the full settings profile is saved along with it. If it's just a gcode file, you would have to manually look through the gcode file to see the settings as they are usually included. Loading the gcode file in cura may bring some of that across. Couldn't hurt to try.
            • paolozampini1973
              paolozampini1973 @Phaedrux last edited by paolozampini1973
              @phaedrux said in internal precision and external pressure DueT WiFi:
              this profile was perfect for me the problem i lost it and i'm trying to do it but it's not easy you can give me a hand please thank you No, I haven't saved the file, I only have the g-code
              RONDELLA 30MM TEST PRECISIONE.gcode
                The end of the gcode file has the settings, but they aren't very easy to read. Have you tried loading the gcode file in Cura yet? If that doesn't work, then you'd have to manually look at the settings listed and make changes to the profile.
                ;End of Gcode
                ;SETTING_3 {"global_quality": "[general]\\nversion = 4\\nname = sunlu U0.80.3 0.
                ;SETTING_3 6 0.7 ON COMBING 60MM di\\ndefinition = custom\\n\\n[metadata]\\ntype
                ;SETTING_3  = quality_changes\\nquality_type = fast\\nsetting_version = 17\\n\\n
                ;SETTING_3 [values]\\nadaptive_layer_height_enabled = False\\nadaptive_layer_hei
                ;SETTING_3 ght_variation = 0\\nadhesion_extruder_nr = 1\\nadhesion_type = none\\
                ;SETTING_3 nadhesion_z_offset = 0\\ndefault_material_bed_temperature = 55\\ninfi
                ;SETTING_3 ll_extruder_nr = 1\\njerk_enabled = False\\nlayer_height = 0.3\\nlaye
                ;SETTING_3 r_height_0 = 0.6\\nmaterial_bed_temperature = 45.0\\nmaterial_bed_tem
                ;SETTING_3 perature_layer_0 = 45.0\\nprint_sequence = all_at_once\\nretraction_c
                ;SETTING_3 ombing = all\\nroofing_extruder_nr = 1\\nspeed_slowdown_layers = 2\\n
                ;SETTING_3 top_bottom_extruder_nr = 1\\ntravel_retract_before_outer_wall = True\
                ;SETTING_3 \nwall_extruder_nr = 1\\n\\n", "extruder_quality": ["[general]\\nvers
                ;SETTING_3 ion = 4\\nname = sunlu U0.80.3 0.6 0.7 ON COMBING 60MM di\\ndefinitio
                ;SETTING_3 n = custom\\n\\n[metadata]\\ntype = quality_changes\\nquality_type =
                ;SETTING_3 fast\\nintent_category = default\\nposition = 0\\nsetting_version = 1
                ;SETTING_3 7\\n\\n[values]\\nalternate_extra_perimeter = True\\nbottom_layers =
                ;SETTING_3 2\\nbottom_thickness = 2\\nbrim_line_count = =math.ceil(brim_width /
                ;SETTING_3 (skirt_brim_line_width * initial_layer_line_width_factor / 100.0))\\n
                ;SETTING_3 brim_outside_only = True\\nbrim_width = 4.0\\ncoasting_enable = False
                ;SETTING_3 \\nconical_overhang_angle = 45\\nconical_overhang_enabled = False\\nc
                ;SETTING_3 onnect_infill_polygons = True\\ncool_fan_enabled = True\\ncool_fan_fu
                ;SETTING_3 ll_at_height = 2\\ncool_fan_speed = 10.0\\ncool_min_layer_time = 0\\n
                ;SETTING_3 cross_infill_pocket_size = =infill_line_distance\\ndefault_material_p
                ;SETTING_3 rint_temperature = 208.0\\ninfill_line_width = 0.9\\ninfill_multiplie
                ;SETTING_3 r = 1\\ninfill_overlap = =10 if infill_sparse_density < 95 and infill
                ;SETTING_3 _pattern != 'concentric' else 0\\ninfill_pattern = lines\\ninfill_spa
                ;SETTING_3 rse_density = 100\\nlimit_support_retractions = False\\nline_width =
                ;SETTING_3 1\\nmaterial_final_print_temperature = =max(-273.15, material_print_t
                ;SETTING_3 emperature - 15)\\nmaterial_initial_print_temperature = =max(-273.15,
                ;SETTING_3  material_print_temperature - 10)\\nmaterial_print_temperature = =def
                ;SETTING_3 ault_material_print_temperature\\nmaterial_print_temperature_layer_0
                ;SETTING_3 = =material_print_temperature\\nmeshfix_extensive_stitching = False\\
                ;SETTING_3 nmin_infill_area = 99999999\\nmin_skin_width_for_expansion = =top_lay
                ;SETTING_3 ers * layer_height / math.tan(math.radians(max_skin_angle_for_expansi
                ;SETTING_3 on))\\nmultiple_mesh_overlap = 0.3\\noptimize_wall_printing_order = T
                ;SETTING_3 rue\\nouter_inset_first = True\\nretract_at_layer_change = True\\nret
                ;SETTING_3 raction_amount = 6\\nretraction_extrusion_window = =retraction_amount
                ;SETTING_3 \\nretraction_hop = 1\\nretraction_hop_enabled = False\\nretraction_h
                ;SETTING_3 op_only_when_collides = True\\nretraction_speed = 70\\nroofing_layer_
                ;SETTING_3 count = 2\\nroofing_pattern = lines\\nskin_line_width = 0.8\\nskin_ou
                ;SETTING_3 tline_count = 2\\nskin_overlap = =5 if top_bottom_pattern != 'concent
                ;SETTING_3 ric' else 0\\nskin_overlap_mm = =0.5 * (skin_line_width + (wall_line_
                ;SETTING_3 width_x if wall_line_count > 1 else wall_line_width_0)) * skin_overla
                ;SETTING_3 p / 100 if top_bottom_pattern != 'concentric' else 0\\nskirt_brim_lin
                ;SETTING_3 e_width = 0.9\\nskirt_brim_minimal_length = 250\\nskirt_brim_speed =
                ;SETTING_3 20.0\\nslicing_tolerance = inclusive\\nspeed_infill = 70\\nspeed_laye
                ;SETTING_3 r_0 = =speed_print * 30 / 60\\nspeed_print = 70\\nspeed_print_layer_0
                ;SETTING_3  = 20.0\\nspeed_roofing = 70\\nspeed_topbottom = 70\\nspeed_travel =
                ;SETTING_3 130\\nspeed_travel_layer_0 = 20.0\\nspeed_wall = 60\\nspeed_wall_0 =
                ;SETTING_3 70\\nspeed_wall_x = 70\\nsupport_line_distance = 10.5\\nsupport_patte
                ;SETTING_3 rn = lines\\nswitch_extruder_retraction_speeds = 70\\ntop_bottom_patt
                ;SETTING_3 ern = lines\\ntop_bottom_thickness = 2\\ntop_layers = 4\\ntravel_avoi
                ;SETTING_3 d_supports = True\\nwall_0_wipe_dist = 0.04\\nwall_line_width = 0.8\\
                ;SETTING_3 nwall_line_width_0 = =wall_line_width\\nwall_line_width_x = 0.8\\nwal
                ;SETTING_3 l_overhang_angle = 90\\nwall_thickness = 150\\nxy_offset_layer_0 = 0\
                ;SETTING_3 \nzig_zaggify_infill = True\\n\\n", "[general]\\nversion = 4\\nname =
                ;SETTING_3  sunlu U0.80.3 0.6 0.7 ON COMBING 60MM di\\ndefinition = custom\\n\\n
                ;SETTING_3 [metadata]\\ntype = quality_changes\\nquality_type = fast\\nintent_ca
                ;SETTING_3 tegory = default\\nposition = 1\\nsetting_version = 17\\n\\n[values]\
                ;SETTING_3 \nalternate_extra_perimeter = True\\nbottom_layers = 2\\nconnect_infi
                ;SETTING_3 ll_polygons = True\\nconnect_skin_polygons = True\\ncool_fan_enabled
                ;SETTING_3 = False\\nexpand_skins_expand_distance = =wall_line_width_0 + (wall_l
                ;SETTING_3 ine_count - 1) * wall_line_width_x\\nfill_perimeter_gaps = nowhere\\n
                ;SETTING_3 filter_out_tiny_gaps = False\\ninfill_enable_travel_optimization = Tr
                ;SETTING_3 ue\\ninfill_line_distance = =0 if infill_sparse_density == 0 else (in
                ;SETTING_3 fill_line_width * 100) / infill_sparse_density * (2 if infill_pattern
                ;SETTING_3  == 'grid' else (3 if infill_pattern == 'triangles' or infill_pattern
                ;SETTING_3  == 'trihexagon' or infill_pattern == 'cubic' or infill_pattern == 'c
                ;SETTING_3 ubicsubdiv' else (2 if infill_pattern == 'tetrahedral' or infill_patt
                ;SETTING_3 ern == 'quarter_cubic' else (1 if infill_pattern == 'cross' or infill
                ;SETTING_3 _pattern == 'cross_3d' else 1))))\\ninfill_material_flow = 100.0\\nin
                ;SETTING_3 fill_pattern = concentric\\ninfill_sparse_density = 100.0\\nline_widt
                ;SETTING_3 h = 0.7\\nmaterial_final_print_temperature = 235.0\\nmaterial_initial
                ;SETTING_3 _print_temperature = 235.0\\nmaterial_print_temperature = 235.0\\nmat
                ;SETTING_3 erial_print_temperature_layer_0 = 235.0\\nmaterial_standby_temperatur
                ;SETTING_3 e = 220.0\\nmeshfix_extensive_stitching = True\\nmeshfix_union_all =
                ;SETTING_3 True\\noptimize_wall_printing_order = False\\nouter_inset_first = Fal
                ;SETTING_3 se\\nretract_at_layer_change = False\\nretraction_amount = 6.0\\nretr
                ;SETTING_3 action_min_travel = =line_width * 2\\nretraction_speed = 70.0\\nroofi
                ;SETTING_3 ng_layer_count = 1\\nskin_preshrink = =wall_line_width_0 + (wall_line
                ;SETTING_3 _count - 1) * wall_line_width_x\\nskirt_brim_minimal_length = 30.0\\n
                ;SETTING_3 slicing_tolerance = inclusive\\nspeed_infill = 60.0\\nspeed_layer_0 =
                ;SETTING_3  20.0\\nspeed_print = 60.0\\nspeed_roofing = 60.0\\nspeed_topbottom =
                ;SETTING_3  60.0\\nspeed_travel = 60.0\\nspeed_travel_layer_0 = 40.0\\nspeed_wal
                ;SETTING_3 l = =speed_print / 2\\nspeed_wall_0 = 60.0\\nspeed_wall_x = 60.0\\nsp
                ;SETTING_3 eed_z_hop = 40.0\\ntop_bottom_pattern = concentric\\ntop_bottom_patte
                ;SETTING_3 rn_0 = concentric\\ntop_layers = 2\\ntravel_avoid_distance = =machine
                ;SETTING_3 _nozzle_tip_outer_diameter / 2 * 1.25\\ntravel_avoid_supports = True\
                ;SETTING_3 \ntravel_compensate_overlapping_walls_enabled = True\\nwall_0_wipe_di
                ;SETTING_3 st = =machine_nozzle_size / 2\\nwall_thickness = 2.1\\nz_seam_corner
                ;SETTING_3 = z_seam_corner_inner\\nzig_zaggify_infill = True\\n\\n", "[general]\
                ;SETTING_3 \nversion = 4\\nname = sunlu U0.80.3 0.6 0.7 ON COMBING 60MM di\\ndef
                ;SETTING_3 inition = custom\\n\\n[metadata]\\ntype = quality_changes\\nquality_t
                ;SETTING_3 ype = fast\\nintent_category = default\\nposition = 2\\nsetting_versi
                ;SETTING_3 on = 17\\n\\n[values]\\ncool_fan_enabled = False\\n\\n", "[general]\\
                ;SETTING_3 nversion = 4\\nname = sunlu U0.80.3 0.6 0.7 ON COMBING 60MM di\\ndefi
                ;SETTING_3 nition = fdmprinter\\n\\n[metadata]\\ntype = quality_changes\\nqualit
                ;SETTING_3 y_type = fast\\nintent_category = default\\nposition = 3\\nsetting_ve
                ;SETTING_3 rsion = 17\\n\\n[values]\\n\\n"]}
                paolozampini1973 2 Replies Last reply Reply Quote 0
                • paolozampini1973
                  ;End of Gcode
                  Yes, thanks, thanks I don't know why I didn't look at it. Thanks. Now I look at it. Thanks
                  • paolozampini1973
                    ;End of Gcode
                    Look I've seen now you can import it just go to the cura settings profile and import g-code
