    Driver Errors Duet2 Railcore 3D Printer
    1.5k
    • MKMachining 0undefined
      MKMachining 0
      My duet2 recently was broken so i had it replaced with a new one. After setting it up with the up to date configuration there was an error that kept showing up with the drivers.
      "Driver 1 error: over temperature shutdown, phase B short to ground"
      "Driver 2 error: over temperature shutdown"
      and others in that variation
      Here is the Diagnostics
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S4-6J1FA-3S86L-KB1LL
      Used output buffers: 1 of 24 (24 max)
      Static ram: 23868
      Dynamic ram: 74492 of which 92 recycled
      Never used RAM 13556, free system stack 134 words
      Tasks: NETWORK(ready,10.6%,243) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,296) MAIN(running,89.3%,440) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:33:20 ago, cause: software
      Last software reset at 2022-03-30 12:27, reason: User, GCodes spinning, available RAM 13700, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 40.7, current 41.5, max 43.7
      Supply voltage: min 1.7, current 24.2, max 24.3, under voltage events: 1, over voltage events: 0, power good: yes
      Events: 12 queued, 12 completed
      Driver 0: ok, SG min n/a
      Driver 1: ok, SG min n/a
      Driver 2: ok, SG min n/a
      Driver 3: ok, SG min n/a
      Driver 4: ok, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2022-03-30 13:00:34
      Slowest loop: 15.30ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.3ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 3, maxWait 1604531ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 10, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 199.88ms; fastest: 0.07ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.26
        WiFi MAC address e0:98:06:22:e6:1f
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 26984
        WiFi IP address 192.168.0.177
        WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        MKMachining 0
        Error: Driver 0 error: over temperature shutdown, phase B short to ground
        Error: Driver 1 error: over temperature shutdown, phase B short to ground
        Error: Driver 2 error: over temperature shutdown, phase B short to ground
        Error: Driver 3 error: phase B short to ground
        Error: Driver 4 error: over temperature shutdown, phase B short to ground
          Please post your config.g and the results of M98 P"config.g"
          Are the driver chips themselves hot?
          Do the errors remain if you disconnect all of the motors (when the board power is off)?
          MKMachining 0undefined 3 Replies Last reply Reply Quote 0
            MKMachining 0 @Phaedrux
            @phaedrux
            M98 P"config.g"
            Error: in file macro line 7: M540: invalid MAC address
            ok
            ; Configuration file for My Printer
            ; Communication and general
            M111 S0 ; Debug off
            M550 PRailCore 4 ; Machine name and Netbios name (can be anything you like)
            ;M551 Pmyrap ; Machine password (used for FTP)
            ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
            M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEE ; MAC Address
            ;*** Wifi Networking
            M552 S1 ; Enable WiFi
            M555 P2 ; Set output to look like Marlin
            M575 P1 B57600 S1 ; Comms parameters for PanelDue
            G21 ; Work in millimetres
            ; Axis and motor configuration
            M669 K1 ; RRF3 change M667 to M669 ; set CoreXY mode
            M584 X0 Y1 Z5:6:7 E3:4:8:9 ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
            M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
            M569 P1 S1 ; Drive 1 goes backwards Y Stepper (Front)
            M569 P2 S1 ; Drive 2 goes forwards Unused
            M569 P3 S0 ; Drive 3 goes forwards Extruder
            M569 P4 S1 ; Drive 4 goes forwards Extruder (unused)
            M569 P5 S0 ; Drive 5 goes backwards Front Left Z
            M569 P6 S0 ; Drive 6 goes backwards Rear Left Z
            M569 P7 S0 ; Drive 7 goes backwards Right Z
            ;Leadscrew locations
            M671 X-10:-10:333 Y22.5:277.5:150 S7.5 ;Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
            M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping for axes& extruder, with interpolation
            ;RRF3 comment out: M574 X1 Y1 Z0 S1
            M574 X1 S1 P"xstop" ; RRF3 set X endstop to xstop port active high
            M574 Y2 S1 P"ystop" ; RRF3 set Y endstop to ystop port active low
            M906 X1400 Y1400 Z1000 E800 I60 ; Set motor currents (mA)
            M201 X3000 Y3000 Z100 E1500 ; Accelerations (mm/s^2)
            M203 X24000 Y24000 Z900 E3600 ; Maximum speeds (mm/min)
            M566 X1000 Y1000 Z100 E1500 ; Maximum jerk speeds mm/minute
            M208 X290 Y290 Z280 ; set axis maxima and high homing switch positions (adjust to suit your machine)
            M208 X0 Y0 Z-0.5 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
            M92 X200 Y200 Z1600 E837 ; steps/mm
            ; Thermistors
            ;RRF3 comment out: M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
            M308 S0 P"bedtemp" Y"thermistor" A"bed_heat" T100000 B3950 R4700 H0 L0 ;RRF3 Bed thermistor, connected to bedtemp on Duet2
            ;If you have a Slice Engineering thermistor, comment out the next line
            ;RRF3 comment out: M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
            M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T100000 B4725 R4700 C7.06e-8 H0 L0 ;RRF3 duet3 e3d
            ;If you have a Slice Engineering thermistor, uncomment the next lines. KITS DO NOT SHIP WITH A SLICE THERMISTOR - ONLY UNCOMMENT IF YOU ORDERED ONE
            ;M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T500000 B4723 R4700 C1.196220e-7 ;RRF3 slice thermistor
            M950 H0 C"e6temp" T0 ;RRF3 define Bed heater is on bedheat
            M950 H1 C"e0heat" T1 ;RRF3 define Hotend heater is on e0heat
            M307 H0 A240.3 C608.7 D8.2 S1.00 V24.1 B0 ; Bed Heaters
            M307 H1 A270.7 C90.4 D6.7 B0 S1.0 ;Heater 1 model
            M570 S360 ; Hot end may be a little slow to heat up so allow it 180 seconds
            M143 S300
            M950 F0 C"fan0" ;RRF3 define fan0
            M950 F1 C"fan1" ;RRF3 define fan1
            M950 F2 C"fan2" ;RRF3 define fan2
            M106 P0 H-1 ; disable thermostatic mode for fan 0
            M106 P1 H-1 ; disable thermostatic mode for fan 1
            M106 P2 H-1
            M106 P0 S0 ; turn off fans
            M106 P1 S0
            M106 P2 S0
            ; Tool definitions
            M563 P0 D0 H1 ; Define tool 0
            G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
            ;*** If you have a single-nozzle build, comment the next 2 lines
            ;M563 P1 D1 H2 ; Define tool 1
            ;G10 P1 S0 R0 X0 Y17 ; Set tool 1 operating and standby temperatures
            ; Z probe and compensation definition
            ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
            ; IR PRobe - uncomment the following 2 lines if you have a and IR Probe, and comment out the BLTouch section below
            ;RRF3 IR Probe only comment out: M558 P1 X0 Y0 Z1 ; Z probe is an IR probe and is not used for homing any axes
            ;M558 P1 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; RRF3 IR Probe connected to Z probe IN pin
            ;G31 X0 Y30 Z2.00 P500 ; Set the zprobe height and threshold (put your own values here)
            ;BLTouch - comment out the following 3 lines if using a IR Probe
            ;RRF3 comment out: M307 H3 A-1 C-1 D-1
            ;RRF3 comment out: M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
            M558 P9 C"^zprobe.in" H5 R1 F50 T6000 A5 S0.02 ; RRF3 BLTouch connected to Z probe IN pin
            M950 S0 C"duex.pwm1" ; RRF3 Define BLTouch Servo (S0) on duet pwm1
            G31 X2 Y42 Z2.65 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
            T0 ; select first hot end
              @phaedrux
              Yes the chips do seem to be hot and there are no errors when I turn the machine on without the motors connected
                Overtemp shutdown would mean too hot to touch for more than a second.
                Do they still get hot when motors disconnected?
                MKMachining 0undefined 1 Reply Last reply Reply Quote 0
                  @phaedrux
                  They do not when the motors are disconnected
                    Then I would double check that your motor wiring is correct.
                    Are you using a Duex as well? Can you test the drivers there?
                    Has anything changed recently on this printer?
                      @phaedrux
                      Yes it is using a duex, how would I test the drivers from there?
                      The board we had before failed, it was working fine for a few years. The wiring is the same as before, the main visible damage was on the MicroSD card
                        So this is a new board? Has it ever worked?
                        Do you know what the cause of the previous failure was? Seems like a pretty bad short. Was the cause corrected?
                        @mkmachining-0 said in Driver Errors Duet2 Railcore 3D Printer:
                        I fear history may be repeating.
                          @phaedrux
                          This board has only been hooked up for a couple of days now.
                          We are not entirely sure what the cause of the previous short was. Like I said earlier this printer was running fine for quite a few years. It happened when there was an issue with the "always on" port that was being test. It smelled like something was burning which was found to be the SD card. I'm not sure how testing that caused such a big reaction.
                            I think you need to closely inspect the wiring and the board and surrounding area. Something seems to be shorting. Are you able to test the motors in another printer? I fear that whatever caused the previous damage is still present.
                              @phaedrux
                              Yes there are other printers that could test the motors. Do you have any suggestion on how to go about this?
                                Phaedrux Moderator @MKMachining 0
                                connect the motor to the other printer and configure them appropriately and see if they work correctly there or not.
                                • elmoretundefined
                                  elmoret
                                  That SD card damage looks to me like something is shorting +3.3v to a 5v or 24v rail...
                                    @phaedrux
                                    I tried the motors on a different working printer which then showed the same errors.
                                    I then put working motors on the broken printer, the motors then read the same short error
                                    Could it be and issue with the power supply?
                                      @phaedrux said in Driver Errors Duet2 Railcore 3D Printer:
                                      After some time the errors do occur with the disconnected motors
                                        So you tried the motors from your railcore on a different printer and it had the same overtemp/short to ground errors?
                                        And new motors on the railcore had the same as well?
                                        It sounds like you've had a pretty significant short that has maybe damaged the coils of the motors and damaged the drivers.
                                        As I said before, I think you need to closely inspect the wiring and the board and surrounding area. Something seems to be shorting. And I think some damage has already been done.
                                        Can you post some close up well lit photos of the duet? There may be some damaged chips.
                                          This post is deleted!
