    Motion Webcam Server Plugin apparmor Error
    Accessories and Add-ons
    • kiendeleoundefined
      kiendeleo
      I am getting the following error in the syslog when I try to start the webcam server plugin:
      Mar 30 10:30:30 TRONXY-X5SA-Pro DuetPluginService[688]: [info] Plugin MotionWebcamServer: Process has been started (pid 986)
      Mar 30 10:30:30 TRONXY-X5SA-Pro kernel: [  110.702719] audit: type=1400 audit(1648661430.736:18): apparmor="DENIED" operation="open" profile="/opt/dsf/plugins/MotionWebcamServer/**" name="/opt/vc/lib/libvchiq_arm.so" pid=986 comm="motion" requested_mask="r" denied_mask="r" fsuid=996 ouid=0
      Mar 30 10:30:30 TRONXY-X5SA-Pro DuetPluginService[688]: [error] Plugin MotionWebcamServer: /opt/dsf/plugins/MotionWebcamServer/dsf/arm/motion: error while loading shared libraries: libvchiq_arm.so: cannot open shared object file: No such file or directory
      Mar 30 10:30:30 TRONXY-X5SA-Pro DuetPluginService[688]: [info] Plugin MotionWebcamServer: Process has been stopped with exit code 127
      I have a Duet 3 with a Tool Board with an SBC running the official image.
      Any help would be appreciated.
        Can you provide the results of M122 please?
        kiendeleoundefined 1 Reply Last reply Reply Quote 0
          kiendeleo @Phaedrux
          @phaedrux Here you go
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (SBC mode)
          Board ID: 08DJM-956L2-G43S8-6J9FA-3SJ6M-1B0UG
          Used output buffers: 1 of 40 (12 max)
          Static ram: 151000
          Dynamic ram: 66280 of which 128 recycled
          Never used RAM 133192, free system stack 154 words
          Tasks: SBC(resourceWait:,17.1%,474) HEAT(notifyWait,0.4%,321) Move(notifyWait,0.1%,262) CanReceiv(notifyWait,0.7%,772) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.2%,339) TMC(notifyWait,257.6%,92) MAIN(running,3003.1%,923) IDLE(ready,0.4%,30), total 3279.5%
          Owned mutexes: HTTP(MAIN)
          Last reset 01:38:26 ago, cause: software
          Last software reset at 2022-03-30 10:18, reason: User, GCodes spinning, available RAM 133480, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Step timer max interval 134
          MCU temperature: min 39.0, current 40.2, max 40.4
          Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.7, current 12.0, max 12.6, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 328, reads 16547, writes 24 timeouts 0
          Driver 1: standstill, SG min 0, mspos 888, reads 16548, writes 24 timeouts 0
          Driver 2: standstill, SG min 0, mspos 600, reads 16553, writes 19 timeouts 0
          Driver 3: standstill, SG min 0, mspos 824, reads 16553, writes 19 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 16561, writes 11 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 16561, writes 11 timeouts 0
          Date/time: 2022-03-30 11:56:50
          Slowest loop: 55.18ms; fastest: 0.04ms
          === Storage ===
          Free file entries: 10
          DMs created 125, segments created 3, maxWait 4478021ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 11, completed 11, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0: no data received
          === CAN ===
          Messages queued 53162, received 121055, lost 0, boc 0
          Longest wait 2ms for reply type 6026, peak Tx sync delay 264, free buffers 50 (min 49), ts 29534/29533/0
          Tx timeouts 0,0,0,0,0,0
          === SBC interface ===
          Transfer state: 4, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 9912/9912
          SPI underruns 0, overruns 0
          State: 5, disconnects: 2, timeouts: 2, IAP RAM available 0x2b880
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4.0
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 39.02, max time between full transfers: 56.3ms, max pin wait times: 53.6ms/4.2ms
          Codes per second: 0.01
          Maximum length of RX/TX data transfers: 3184/252
            Have you done a sudo apt update sudo apt upgrade?
              kiendeleo @Phaedrux
              @phaedrux yes
                I wonder if your problem is related to this one.
                https://forum.duet3d.com/topic/27500/motionwebcamserver-plugin-missing-library?_=1648667030984
                Take a look and see what you think.
                  kiendeleo @Phaedrux
                  @phaedrux I didn't find that forum post when I searched for this error, weird. Thank you for your help.
                  This was the fix:
                  @chrishamm said in MotionWebcamServer plugin - Missing library:
                  @adammhaile @luckyflyer Very odd, it looks like something changed because this definitely worked for me before on another image. The problem is indeed that motion cannot open /opt/vc/lib/libvchiq_arm.so. To fix this, you can edit /etc/apparmor.d/dsf.MotionWebcamServer and insert a new line below /usr/local/lib...:
                    /opt/vc/lib/** rm,
                  Then reboot the Pi or run sudo apparmor_parser -r /etc/apparmor.d/dsf.MotionWebcamServer and you should be able to start the plugin from DWC.
                  It looks like there is also an issue with Motion's custom log file location for permission:
                  motion[1762]: [0:motion] [EMG] [ALL] motion_startup: Exit motion, cannot create log file /var/log/motion/motion.log: Permission denied
                  This is an optional configuration item though so the short-term fix is to just disable the feature.
