    CTC Heated Bed Thermistor
    • bug2k22undefined
      bug2k22
      I've just picked up a Duet2 Ethernet to replace the original mightyboard that came with the CTC. I also ordered the thermocouple daughter board for the extruder thermocouple (I removed the second extruder some time ago).
      From what I've read the heated bed has a 100k thermistor with a resistor in series, will this work with the Duet2?
        Yes it should work. Do you have an idea what the B value might be? Is it a common 100k 3950?
        bug2k22undefined 1 Reply Last reply Reply Quote 0
        • bug2k22undefined
          bug2k22 @Phaedrux
          @phaedrux I'm not too sure on this ctc, but it's pretty much a clone of the original makerbot replicator which looking at the wiki says "Thermistor 100K 1206 1%, most probable the NTHS1206N01N1003FE, B value 3964 K"
          makerbot heatbed schematic
          It has a 4pin connector which has the pins +5v/gnd/gnd/Signal.
            I don't think I've ever seen a 4 wire thermistor
              dc42 administrators @Phaedrux
              I suggest you connect the thermistor GND/PAD1 connection to the VSSA pin of a thermistor input on the Duet and SIG_PAD1 or PAD5 to the other pin of the thermistor input. Leave VCC-PAD6 not connected.
              • bug2k22undefined
                bug2k22 @dc42
                @dc42 That seems to have worked fine, both the extruder thermocouple and the heated bed thermistor are working. I think the temperature readings are out, the bed shows ~31degC at idle whereas the extruder seems to show ~16degC which is probably about right for ambient.
                I do think the extruder is under reading at working temps as printing at a reported 198 seems quite a bit higher than needed to print pla. I don't have a ir thermometer to check at the moment.
