Z-stepping to short?
  • I don't think my Z is advancing as fast as I need it to.
    Is there a way I can config it to keep up?
    Have you set the Z steps per mm correctly?
  • That seems not a steps/mm Issue cause the X is clearly readable. Only a gap betwwen ~ Lyer 10 and the next (or is this a brim?)and the Rest above. Seems more a mechanical issue. Cause wrong steps will be noticeable everywhere and the X will not as clear as this one.
  • During the print I kept having to add baby z-steps so it would not damage my hotend by it running back into the print
    If the problem is not consistent enough to be incorrect steps/mm then I think it's either a mechanical issue or caused by your Z acceleration or Z maximum speed being settling high.
  • It starts after the first layer is down then it just gets worse after that.
  • Here is my config I have matched to a few on this forum and I think I got it right.
    ; CoreXY sample config file for dc42 Duet firmware
    M111 S0 ; Debug off
    M550 PBig-D ; Machine name (can be anything you like)
    M551 Preprap ; Machine password (used for FTP connections)
    ns)
    ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
    ;*** Wifi Networking
    M552 S1 ; Enable WiFi
    M555 P2 ; Set output to look like Marlin
    ;M575 P1 B57600 S1 ; Comms parameters for PanelDue
    ; Machine configuration
    M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it)
    M569 P4 S1 ; Drive 4 goes forwards
    ; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
    M574 X1 Y2 Z1 S0 ; set endstop configuration (X and Y and endstops only, at low end, active high)
    M667 S1 ; set CoreXY mode
    M350 X64 Y64 Z64 E64 I0 ; Set 16x microstepping with interpolation
    M92 X400 Y400 Z1600 ; Set axis steps/mm
    M92 E1643:1643 ; Set extruder steps/mm
    M584 E4
    M906 X800 Y800 Z800 E1400 ; Set motor currents (mA)
    M201 X1000 Y1000 Z300 E4000 ; Accelerations (mm/s^2)
    M203 X15000 Y15000 Z500 E1500 ; Maximum speeds (mm/min)
    M566 X800 Y800 Z24 E1200 ; Maximum jerk speeds mm/minute
    M208 X290 Y285 Z320 ; set axis maxima (adjust to suit your machine)
    M208 X-10 Y0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
    G21 ; Work in millimetres
    ; Z probe
    M558 P1 X0 Y0 Z0 ; Analog Z probe, also used for homing the Z axis
    ;G31 Z2.47 P500 S1 ; Set the probe height and threshold (put your own values here)
    ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
    ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
    ;M557 P0 X30 Y25 ; Four...
    ;M557 P1 X30 Y155 ; ...probe points...
    ;M557 P2 X250 Y125 ; ...for bed...
    ;M557 P3 X250 Y25 ; ...levelling
    ;M557 P4 X150 Y95 ; 5th probe point for levelling
    ; Thermistors and heaters
    ;*** You can use S and B parameters to define the parameters of the thermistors you are using
    M305 P0 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
    M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
    M305 P2 T100000 B3974 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
    M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
    M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
    M570 S120 ; Increase to allow extra heating time if needed
    M307 H0 A86.7 C612.7 D6.0 B0
    M307 H1 A406.3 C166.4 D10.3 B0
    M106 P0 T50 H1
    M106 P1 T50 H1
    M106 P2 T50 H1
    ; Tool definition
    M563 P0 D0 H1 ; Define tool 0
    G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
    ;*** If you have a dual-nozzle build, un-comment the following 3 lines
    ;M563 P1 D1 H2 ; Define tool 1
    ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
    ;*** If you are using axis compensation, put the figures in the following command
    M556 S78 X0 Y0 Z0 ; Axis compensation here
    T0 ; select first hot end
