Upgrade from Duet2 Wifi to Duet3
What is the easiest most pain free way to do this?
I know I have to redo some cable ends and connectors but can I Just drop my RRF 3.X config.g and associated files onto it and go to town?
@efletcher pretty much. Config wise, the main differences are the pin names. Otherwise you should be golden
is there an easy non computer literate way to go about the pin names?
A conversion chart?
One would think there would be a conversion "Wizard"
https://configtool.reprapfirmware.org/Start
This is as close to a wizard as you'll get.
