    RRF Config Tool - Steps/mm Calculator
    Config Tool
    • Nightowlundefined
      Nightowl
      I'm using the Duet3 MB6HC to control my KillerBee 1075, which has TR8*8 trapezoidal lead screws, yet this option isn't available.
      As I'm completely new to this and terrified of making any costly mistakes, should I use the 'Custom' option and set the pitch from the information I've gleaned from RatRig's website, please?
      Thank you.
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        For TR8*8 you should be able to choose custom and then set the lead to 8.
        Or you can use the formula to confirm:
        Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @Phaedrux
          Brilliant, thank you @phaedrux.
          Just some clarification, though, please. Are you saying the lead should be 8 because the TR8*8 has a pitch of 2mm but 4 has start points (if my terminology is correct).
          Thanks
            Yes, it's the lead that is important.
