    Smart Effector z-probe always on 1000
    400
    • akinoriundefined
      akinori
      Hello, I have Duet 2 Ethernet (rev. 1.3, soft ver. 3.4) and Smart Effector (rev. 3.0). I tried almost everything to went through auto callibration but always my z-probe value's 1000 and callibration process's end immediately. I'm sure cable wiring is corectly done. Crimps are deep in connectors. I tried tips from similar topic but it doesn't help: https://forum.duet3d.com/topic/2739/z-probe-stuck-at-1000-with-smart-affector (shorting pin of z-probe on duet board give 0 value like it should). I'm fighting with duet 2 and smart effector nearly a month and I'm losing hope it will finally work
      My config.g file:
      ; Configuration file for Duet Ethernet (firmware version 3.4)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 21:42:46 GMT+0100 (czas środkowoeuropejski standardowy)
      ; Delta Settings
      M665 L440.380 R226.821 H407 B185.0 X0 y0 z0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 y0 z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
      M550 P"Anycubic Predator" ; Set machine name
      M551 P"" ; Set password
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80.00 Y80.00 Z80.00 E415 ; Set steps per mm
      M566 X3000 Y3000 Z3000 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z12000.00 E12000 ; Set maximum speeds (mm/min)
      M201 X9000.00 Y9000.00 Z9000.00 E6000.00 ; Set accelerations (mm/s^2)
      M906 X1400.00 Y1400.00 Z1400.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Retraction
      M207 S2.5 F7000 R0.1 T2500 Z0.5 ; Firmware retraction
      M208 Z0 S1 ; Set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P5 R0.4 H3 F1200 T6000 C"zprobe.in+zprobe.mod" ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
      M557 R180 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
      M563 P0 D0 H1 ; Define tool 0
      M591 D0 P2 C4 S1 ; Activate filament sensor
      M404 N1.75 ; Set for print monitor
      M575 P1 B57600 S1 ; Paneldue baud rate
        @akinori said in Smart Effector z-probe always on 1000:
        I assume you're going through this? https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Smart_Effector
        Can you send M122 and M98 P"config.g" and post the results?
        Can you disassemble the smart effector and take some clear close up photos of both sides?
        If you connect it when not mounted does it report differently?
        akinoriundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @akinori
          @akinori is the green LED on the Smart Effector working normally? It should be off normally, but flash when you tap the nozzle upwards.
          • akinoriundefined
            akinori @Phaedrux
            @phaedrux
            Yeah, I go step by step with this guide. I disassemble effector but, probe-z value is still on 1000 :c
            5.04.2022, 18:17:43 M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: in file macro line 77 column 13: M591: expected string expression
            Warning: Macro file config-override.g not found
            5.04.2022, 18:17:28 M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet Ethernet 1.02 or later
            Board ID: 08DJM-9178L-L2MS8-6JTD6-3SS6N-19DLQ
            Used output buffers: 6 of 24 (12 max)
            Static ram: 23868
            Dynamic ram: 69092 of which 268 recycled
            Never used RAM 18852, free system stack 192 words
            Tasks: NETWORK(ready,21.0%,240) HEAT(notifyWait,0.0%,338) Move(notifyWait,0.0%,364) MAIN(running,75.6%,448) IDLE(ready,3.4%,30), total 100.0%
            Owned mutexes:
            Last reset 00:00:25 ago, cause: power up
            Last software reset at 2022-04-04 19:10, reason: User, GCodes spinning, available RAM 16112, slot 1
            Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 0
            MCU temperature: min 26.0, current 29.2, max 29.6
            Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min n/a
            Driver 1: standstill, SG min n/a
            Driver 2: standstill, SG min n/a
            Driver 3: standstill, SG min n/a
            Driver 4: standstill, SG min n/a
            Driver 5:
            Driver 6:
            Driver 7:
            Driver 8:
            Driver 9:
            Driver 10:
            Driver 11:
            Date/time: 2022-04-05 18:17:25
            Cache data hit count 938378659
            Slowest loop: 5.74ms; fastest: 0.19ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 3.4ms, write time 0.0ms, max retries 0
            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty
            === Network ===
            Slowest loop: 8.50ms; fastest: 0.02ms
            Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            HTTP sessions: 1 of 8
            Interface state active, link 100Mbps full duplex
            @dc42 LED is blink 2 times when power on, but it doesn't react when I tap nozzle.
              When and where was your smart effector purchased?
              • akinoriundefined
                akinori @Phaedrux
                @phaedrux Through this website http://filament23d.dk
                It was closest avaible option. I bought it 12/02/2022 and arrived to me in Poland around two weeks later.
                I wrote to hobby-store.pl about the chance to buy this part but they did not respond to me
                  We shall see if DC42 has any other ideas.
                    @akinori I think you may have a wiring error between the Smart Effector and the Duet. Please post photos of both ends of the cable between the 8-pin connector on the effector and the Z probe connector on the Duet.
                    • akinoriundefined
                      akinori @dc42
                      @dc42 You had right! Mi wires was connected in proper order but, for some reason it doesn't work. But I use different wires, crimped again and everything works 😄
