    Printing problem duet fw config bad or Siemens drivers bad
    Firmware installation
    238
    • createc3d
      createc3d last edited by
      we already have a working big 3D printer with Duet 3 6HC and Nema 23 stepper motors, all with their external drivers boards Duet 3 expansion board 1 XD, now it's working fine with no problems.
      We assembled other machine but with Siemens servo motors (1FL6032-2AF21-1AA1) and servo drives (6SL3210-5FB10-2UA2) that works by pulse, but the result of the printing is this:
      Circles are not circles... in one direction seems to print fine but in others not... see the triangle figure for example... or X...
      The Gcode is made with Simplify like in all our machines.
      We have the firmware of duet config tested on normal steppers and works good so we think the problem is the configuration of Servo Drives of Siemens, but people of Siemens said that problem is on Duet board configuration.
      Any ideas?
      Thank you.
      jay_s_uk dc42 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @createc3d last edited by
        @createc3d post your config
          dc42 administrators @createc3d last edited by
          @createc3d it may be that the drivers need slower timings than the default ones provided by the 1XD boards. Please post a link to the datasheet for those drivers, along with your config.g file.
          createc3d 1 Reply Last reply Reply Quote 0
          • createc3d
            createc3d @dc42 last edited by
            @dc42 the drivers are this:
            https://support.industry.siemens.com/cs/dl-media/109793552/142040542347_en-US/start.htm?lc=en
            and the config file is:
            ; Configuration file for Duet 3 (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Feb 24 2022 09:21:45 GMT+0100 (hora estándar de Europa central)
            M550 P"Atarfil"                                    ; set printer name
            M575 P1 S1 B57600
            ; Wait a moment for the CAN expansion boards to start
            G4 S2
            M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
            M569 P40 	S0    	R0 T2.7                               	   ; physical drive 121.0 goes forwards
            M569 P41.0 	S1  	R0 T2.7                                    ; physical drive 122.0 goes forwards
            M569 P42.0 	S1	 	R0 T2.7                                    ; physical drive 123.0 goes forwards
            M569 P43.0 	S1	    R0 T2.7 				 				   ; physical drive 124.0 goes forwards
            M569 P0 S0  		R0  				                       ; R0 MODIFICACION
            M584 X40.0
            M584 Y41.0
            M584 Z42.0
            M584 Z43.0
            M584 E0                                            ; set drive mapping
            M350 X11.11 Y6.25 Z10 E16 I1                               ; configure microstepping with interpolation
            M92 X11.11 Y6.15 Z200  E600                  		   ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z100.00 E1200.00            ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z10.00 E250.00                ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E1680 I30                       ; set motor currents (mA) and motor idle factor in per cent
            M208 X2200 Y200 Z70 S0                            ; set axis maxima
            M574 X1 S1 P"io1.in"                           ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io0.in
            M574 Y1 S1 P"io2.in"                           ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin 122.io0.in
            M574 Z1 S1 P"io3.in+io4.in"                           ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin 123.io0.in
            M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:215 Y15:195 S20                           ; define mesh grid
            M308 S0 P"temp3" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"out0" T0                           ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 A340 C2745.9 D25 S1.00 B0                               ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                         ; map heated bed to heater 0
            M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
            M308 S1 P"temp0" Y"thermistor" T100000 B4138   ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"out1" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
             M307 H1 B0 R1.278 C282.5 D6.68 S1.00 V23.1                             ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280
            M950 F0 C"out5" Q500                               ; create fan 0 on pin out4 and set its frequency
            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out4" Q500                               ; create fan 1 on pin out5 and set its frequency
            M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
            ;M563 P0 S”v4” D0 H1 ; Define tool 0
              dc42 administrators @createc3d last edited by dc42
              @createc3d I was unable to find the parameters required in the document you linked to. The parameters needed are:
              Minimum step pulse width
              Minimum step pulse interval
              Required setup time from change in direction signal to leading edge of step pulse
              Required hold time from trailing edge of step pulse to change in direction signal
              Currently you have set all of these to 2.7 microseconds. I suspect that at least one of them needs to be increased.
              Please upgrade to firmware 3.4.0 if you are not already using it.
              • createc3d
                @dc42 I asked Siemens about the data needed and the only thing they can say is this:
                They use RS 485 to receive pulses at a máximum frecuency of 1MHz...
                They don't tell us anything about "ms" or anything else.
                We may increase randomly to see if it works fine?
                  @createc3d in your M569 commands I suggest you try this T parameter:
                  T2.5:2.5:5:5
                  If that works, try reducing the last value to zero. It's usually the third value that needs to be increased when there are issues with direction changes.
                  createc3d 2 Replies Last reply Reply Quote 0
                  • createc3d
                    @dc42 Ok, we'll try next week and let you know, because the machine is in other company and can't go to check today.
                    Thank you.
                    • createc3d
                      @dc42 hello, we've been testing and it's a bit better but still it's not good.
                      We tried with T2.5:2.5:5:5 but it was not better.
                      Then with T2.5:2.5:5:0 was a little improvement.
                      Then we tried increasing the third value to 10, 20... up to 100 but no change, same results.
                      We also tried without the T parameter and values and the results was the same that T2.5:2.5:5:0.
                      Can we try anything else?
                      jay_s_uk 1 Reply Last reply Reply Quote 0
                      • jay_s_uk
                        @createc3d try T5:5:10:10
                        createc3d 1 Reply Last reply Reply Quote 1
                        • createc3d
                          createc3d @jay_s_uk last edited by
                          @jay_s_uk Hello, still is not doing it right
                            @createc3d if you send M569 P41.0 and similarly for the CAN addresses of the other 1XD boards, does it report the correct T values that you used? Some of them will be rounded up to the next multiple of 1.33us.
                            If you send M98 P"config.g" are there any error messages?
                            dc42 createc3d 2 Replies Last reply Reply Quote 0
                              dc42 administrators @dc42 last edited by
                              PS have you checked for loose pulleys etc.? That pattern of a straight line segment appearing in what should be a circle is characteristic of a large amount of backlash.
                              • createc3d
                                @dc42 Hello, sorry for delay, here with easter week we didn't have the possibility to go to the place where the machine is installed until today.
                                This is the result of M98 P"config.g"
                                P40 and P41 are X and Y axis, P42 is not in use at the moment and P43 is Z axis.
                                And config file is now:
                                M575 P1 S1 B57600
                                G4 S2
                                M569 P40.0 	S0    	R0 T5:5:10:10                               	   ; physical drive 121.0 goes forwards
                                M569 P41.0 	S1  	R0 T5:5:10:10                                  ; physical drive 122.0 goes forwards
                                M569 P42.0 	S1	 	R0 T5:5:10:10                                   ; physical drive 123.0 goes forwards
                                M569 P43.0 	S1	    R0 T5:5:10:10 				 				   ; physical drive 124.0 goes forwards
                                M584 X40.0
                                M584 Y41.0
                                M584 Z42.0
                                M584 Z43.0
                                M143 H1 S280
                                • createc3d
                                  @dc42 we have a person now checking all mechanics in case there's some problem with it also.
                                    @createc3d another test you can do is to approach a particular point (say X=100) from one direction (e.g. from X50) and then from the other (e.g. X150) and check whether the print head goes to exactly the same place in both cases.
                                    • createc3d
                                      @dc42 I'm going to tell the people with the machine to do this test, but I think in linear movement the machine has no problem.
                                      About the information before, why is different the step timming in the drivers if we have in config.g the same for all of them?
                                      • createc3d
                                        @dc42 this test was fine... but we tried to print two lines, one with 45 degrees and other with 3 degrees... the 45º line was drawn ok, but the 3º line the machine only moves in X axis... the Y was not moving... any ideas?
