    BLTouch Duet 2 Wifi didnt work
    • RobiiinX
      RobiiinX last edited by
      Hello, i connect my original BLTouch to my Duet 2 Wifi and changed it in the firmware. But it isnt work. The Pin of the BL didnt get out. But it lights red. But he dont takes his pin out. Do you see the Problem?
      It is connected like here:
      www.duet3d.dozuki.com/wiki/connecting_a_z_probe
      In the Config.g i write:
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F100 T2000
      G31 X19 Y0 Z0 P25
      In deployprobe.g i write:
      M280 P3 S10 I1
      In retractprobe.g i write:
      M280 P3 S90 I1
      Anything other i didnt change.
      Thank you for help
      Hobby-Store RobiiinX 2 Replies Last reply Reply Quote 0
        What firmware version?
        Can you please post your full config.g and your homing files?
        Also the results of sending M122 and M98 P"config.g"
        • Hobby-Store
          Hobby-Store @RobiiinX last edited by
          @robiiinx
          Do you have line like
          M950 S0 C"exp.heater3"
          M558 P9 C"^zprobe.in" H5 F120 T6000
          and try use
          M280 P0 S10
          M280 P0 S90
          look on this docs https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting
          • RobiiinX
            RobiiinX @RobiiinX last edited by
            @Phaedrux
            Here is my whole config
            ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 04 2022 20:14:28 GMT+0200 (Mitteleuropäische Sommerzeit)
            M550 P"My Printer" ; set printer name
            M669 K1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X800.00 Y800.00 Z800.00 E500.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X300 Y300 Z300 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M307 H3 A-1 C-1 D-1
            G31 X19 Y0 Z0 P25; Custom settings are not defined
            Here is the homeall.g
            ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 H1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-305 ; home X axis
            G1 H1 Y-305 ; home Y axis
            G1 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-305 ; then move slowly to Y axis endstop
            G90 ; absolute positioning
            G1 X15 Y15 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G1 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            • Lo-Fi
              Lo-Fi last edited by Lo-Fi
              @robiiinx
              I think the issue is that you're using M307 (RRF 2) where you should be using M950 (RRF3)
              My working config:
              M558 P9 C"^zprobe.in" H1 F120 T9000            ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X45 Y0 Z2.399                         ; set Z probe trigger value, offset and trigger height
              I also have a macro defined for finding the nozzle to probe offset:
              G29 S2						;Disable mesh compensation
              G1 X75 Y75 Z10			; change this to a convenient position on your bed
              G30 						;Extend probe and touch
              G92 Z15						;Allow extra room
              M291 S3 Z1 P"Move nozzle to touch bed"	; dialogue to jog nozzle to bed.
              G92 Z0						;set new zero
              G1 Z10						;move away
              G30 S-1						;see output for offset
              You'll need to feed the measurement it prints to console to the Z parameter of G31. Further reading here:
              https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/#testandcalibrate
              Hopefully that gets you going 🙂
                @phaedrux said in BLTouch Duet 2 Wifi didnt work:
                Please provide this so we can see what firmware version you are using so we know which commands you need to use. Right now you have both commands for RRF2 and RRF3. Most of your config appears to be for RRF3 so I think you should remove these additions.
                M307 H3 A-1 C-1 D-1
                But without knowing for certain what firmware you're using I don't know.
