    Configuration of a MCU controlled fan
    Using Duet Controllers
    364
    • CrazyCreator
      CrazyCreator last edited by CrazyCreator
      Hi there,
      I have problems configuring a MCU temperature dependent fan.
      Hardware: One MB3HC6, Two HC3 and a Raspi 4B
      This is how the fan is configured:
      ; System Temperature Sensors
      M308 S10 Y"mcu-temp" A"MCU"			; defines sensor 10 as MCU temperature sensor
      ; Electronic Cooling
      M950 F8 C"2.out3" Q65535  				; create fan 8 on pin 2.out3 on MB3HC Board #2 and set its frequency
      M106 P8 C"MCU-Fan" T20 H10				; Test MCU TEMP and FAN
      The MCU shows a temperature of 40-45°C, but the fan doesn't move.
      If I set the fan manually:
      M106 P8 C"MCU-Fan" H-1					; set fan 8 value. Thermostatic control is turned OFF
      then I can control it normally.
      can it be that the fan must also be connected to the HC6 board, i.e. the board where the temperature is measured?
      Second question:
      I noticed something else, when I use the rrf config tool, all fans, with a connected sensor, get an H5:XX
      ; Fans for Tool's
      ; Tool 0 --------------------
      ; PartFan for Tool 0
      M950 F0 C"out4" Q500        ; create fan 0 on pin out4 and set its frequency
      M106 P0 C"T0-PF" L0.35 S0 H-1			                                                ; set fan 0 value. Thermostatic control is turned off L0.35 = MinimumSpeed 35%
      ; HotEnd Fan for Tool 0
      M950 F1 C"out5" Q500        ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H5:1 T45        ; set fan 1 value. Thermostatic control is turned on
      ; Tool 1 --------------------
      ; PartFan for Tool 1
      M950 F2 C"out6" Q500        ; create fan 2 on pin out6 and set its frequency
      M106 P2 C"T1-PF" L0.35 S0 H-1			                                                ; set fan 0 value. Thermostatic control is turned off L0.35 = MinimumSpeed 35%
      ; HotEnd Fan for Tool 1
      M950 F3 C"out7" Q500        ; create fan 3 on pin out7 and set its frequency
      M106 P3 S1 H5:2 T45        ; set fan 3 value. Thermostatic control is turned on
      ; Tool 2 --------------------
      ; PartFan for Tool 2
      M950 F4 C"out8" Q500        ; create fan 4 on pin out8 and set its frequency
      M106 P4 C"T2-PF" L0.35 S0 H-1			                                                ; set fan 0 value. Thermostatic control is turned off L0.35 = MinimumSpeed 35%
      ; HotEnd Fan for Tool 2
      M950 F5 C"out9" Q500        ; create fan 5 on pin out9 and set its frequency
      M106 P5 S1 H5:3 T45        ; set fan 5 value. Thermostatic control is turned on
      ; Tool 3 --------------------
      ; PartFan for Tool 3
      M950 F6 C"1.out3" Q500        ; create fan 6 on pin 1.out3 and set its frequency
      M106 P6 C"T3-PF" L0.35 S0 H-1			                                                ; set fan 0 value. Thermostatic control is turned off L0.35 = MinimumSpeed 35%
      ; HotEnd Fan for Tool 3
      M950 F7 C"1.out4" Q500        ; create fan 7 on pin 1.out4 and set its frequency
      M106 P7 S1 H5:4 T45        ; set fan 7 value. Thermostatic control is turned on
      The XX is then the right fan, but what does the 5 mean? Because the 5 then stands in front of the actual fan number for all fans. Everything works perfectly (with and without 5), but the 5 doesn't belong there, does it?
      http://www.crazycreatorcube.com
        Can you share your full config.g and the results of m122 and M98 P"config.g" please?
        CrazyCreator 1 Reply Last reply Reply Quote 0
        • CrazyCreator
          CrazyCreator @Phaedrux last edited by CrazyCreator
          @phaedrux
          M122:
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (SBC mode)
          Board ID: 08DJM-956BA-NA3TN-6JTDG-3S86J-TUB2T
          Used output buffers: 1 of 40 (27 max)
          Static ram: 151000
          Dynamic ram: 69104 of which 12 recycled
          Never used RAM 130556, free system stack 188 words
          Tasks: SBC(resourceWait:,6.3%,471) HEAT(notifyWait,0.2%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.3%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.1%,339) TMC(notifyWait,77.6%,92) MAIN(running,15.4%,923) IDLE(ready,0.1%,30), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 03:32:39 ago, cause: power up
          Last software reset at 2022-04-06 23:13, reason: User, none spinning, available RAM 130480, slot 2
          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 134
          MCU temperature: min 28.6, current 43.8, max 44.1
          Supply voltage: min 23.6, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 8, reads 14753, writes 15 timeouts 0
          Driver 1: standstill, SG min 0, mspos 8, reads 14753, writes 15 timeouts 0
          Driver 2: standstill, SG min 0, mspos 8, reads 14752, writes 16 timeouts 0
          Driver 3: standstill, SG min 0, mspos 8, reads 14752, writes 16 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 14752, writes 16 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 14752, writes 16 timeouts 0
          Date/time: 2022-04-08 00:24:38
          Slowest loop: 2.76ms; fastest: 0.04ms
          === Storage ===
          Free file entries: 10
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 114774, received 407978, lost 0, boc 0
          Longest wait 1ms for reply type 6042, peak Tx sync delay 389, free buffers 50 (min 49), ts 63799/63798/0
          Tx timeouts 0,0,0,0,0,0
          === SBC interface ===
          Transfer state: 4, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 39160/39160
          SPI underruns 0, overruns 0
          State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b880
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4.0
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 5.60, max time between full transfers: 286.7ms, max pin wait times: 87.3ms/12.8ms
          Codes per second: 0.00
          Maximum length of RX/TX data transfers: 4179/756
          M98 P"config.g":
          M98 P"config.g"
          ok
          My complete config.g
          ; CrazyCreatorCube CoreXY ToolChanging Printer - Config File
          ; inspired from jubilee
          ; This file intended for Duet 3 hardware, main board plus two expansion boards and a Raspi
          ; MB6HC6 Mainboard: For XY and Extruders
          ; EXP_MB3HC #1: For Z
          ; EXP_MB3HC #2: For Extras
          ; Name and network ONLY for Info
          ; This is configured from the connected Raspberry Pi or here if in stand alone mode
          ; Networking
          ;M550 P"CCC"				; Name used in ui and for mDNS  http://ccc.local
          ;M552 P192.168.1.44 S1		; Use Ethernet with a static IP, 0.0.0.0 for dhcp
          ;M553 P255.255.255.0		; Netmask
          ;M554 192.168.1.1			; Gateway
          ; General setup
          M111 S0                    	; Debug off
          M929 P"eventlog.txt" S1    	; Start logging to file eventlog.txt
          ; General Preferences
          M555 P2                    	; Set Marlin-style output
          G21                        	; Set dimensions to millimetres
          G90                        	; Send absolute coordinates...
          M83                        	; ...but relative extruder moves
          ; Stepper mapping
          ; Connected to the MB6HC as the table below.
          ; Note: first row is numbered left to right and second row right to left
          ; _______________________________________
          ; | Y(Left) 0 | X(Right)  1 | E(T0) 2 |
          ; | E(T3)  	 5 | EZ(T2)	  4 | E(T1) 3 |
          M584 X0 Y1                	; X and Y for CoreXY
          M584 E2:3:4:5             	; E has 4 drivers for 4 Tools
          ; Connected to the EXP_MB3HC as the table below.
          ; | Z(Right) 0 | Z(Back) 1 | Z(Left) 2 |
          M584 Z1.0:1.1:1.2			; Z has 3 Drivers for Kinematic bed, connected to first MB3HC
          ; ToolChanger-Lock-Drive (C) and in Future the WasteMotors, connected to second MB3HC
          M584 C2.0
          ; M569: Set motor driver direction, enable polarity and step pulse timing on MB6HC
          M569 P0 S0                ; Drive 0 | X stepper
          M569 P1 S0                ; Drive 1 | Y Stepper
          M569 P2 S0 D2             ; Drive 2 | Extruder T0 1400mA Spreadcycle Mode
          M569 P3 S0 D2             ; Drive 3 | Extruder T1 1400mA Spreadcycle Mode
          M569 P4 S0 D2             ; Drive 4 | Extruder T2 1400mA Spreadcycle Mode
          M569 P5 S0 D2             ; Drive 5 | Extruder T3 1400mA Spreadcycle Mode
          ; Connected to EXP_MB3HC #1
          M569 P1.0 S0                	; Drive 1.0 | Front Right Z
          M569 P1.1 S0                	; Drive 1.1 | Back Z
          M569 P1.2 S0                	; Drive 1.2 | Front Left Z
          ; Connected to EXP_MB3HC #2
          M569 P2.0 S0                	; Drive 2.0 | Coupler
          ;M569 P2.1 S0                	; Drive 2.1 | UNUSED - Planed for Wastebox
          ;M569 P2.2 S0                	; Drive 2.2 | UNUSED - Planed for Wastebox
          ; M906: Set motor currents
          M906 X{0.7*sqrt(2)*2000} I30	; LDO XY 2000mA RMS LDO 0.9° Stepper Motor| LDO-42STH60-MAC the TMC5160 driver on duet3 generates a sinusoidal
          M906 Y{0.7*sqrt(2)*2000} I30	; coil current so we can multiply by sqrt(2) to get peak used for M906. Do not exceed 90% without heatsinking the XY steppers.
          								; {0.7*sqrt(2)*1400} 70% of 1400mA E don't support expressions in 3.2.0-beta4
          M906 E1400 C500 I10				; Set Currents for E (Extruder) and C (Coupler) Motors
          M906 Z{0.7*sqrt(2)*1680} I30    ; 70% of 1680mA RMS. Note that the idle will be shared for all drivers - LDO 0.9° Stepper Motor | LDO-42STH48-MAC
          ; Kinematics
          M669 K1                   ; CoreXY mode
          ; Kinematic bed ball locations.
          ; Locations are extracted from CrazyCreatorCube-CAD model assuming lower left build plate corner
          ; is (0, 0) on a 350x350mm plate. This mean the Kinematic Bed Ball Connectors.
          M671 X361:171:-19 Y5.5:358.5:-5.5 S100     		; Front Right: (X361, Y5.5)		0
                                                     		; Back Middle: (X171, Y358.5)	1
          												; Front Left: (X-19, Y-5.5)		2
                                                     		; Up to 100mm correction
          ; __________________________________________
          ; |Y|									 |X|
          ; |||   |E0|  |E1|   |Z1|   |E2|  |E3|   |||
          ; |||Z2|							  |Z0|||
          ; Axis and motor configuration
          M350 X1 Y1 Z1 E1:1:1:1  ; Disable microstepping to simplify calculations
          M92 X{1/(0.9*20/180)}  	; step angle * tooth count / 180
          M92 Y{1/(0.9*20/180)}  	; The 2mm tooth spacing cancel out with diam to radius
          M92 Z{360/0.9/4}       	; 0.9 deg stepper / lead (4mm) of screw
          M92 E51.875:55:60:70	; 51.875 = BMG-Extruder with 0.9 deg/stepper-motor
          M92 C91.022				; E3D-Coupler-Drive
          ; Enable microstepping all step per unit will be multiplied by the new step def
          M350 X16 Y16 I1        	; 16x microstepping for CoreXY axes. Use interpolation.
          M350 Z16 I1            	; 16x microstepping for Z axes. Use interpolation.
          M350 E16:16:16:16 I1   	; 16x microstepping for Extruder axes. Use interpolation.
          M350 C16 I10			; 16x microstepping. Without interpolation.
          ; Acceleration, Speed and Jerk
          ; Acceleration - (mm/s^2) / TitanAero: E5000.00 / Orbiter:E600
          M201 X1100 Y1100                        	; Accelerations (mm/s^2)
          M201 Z100                               	; LDO ZZZ Acceleration
          M201 E1300                              	; Extruder
          M201 C500									; Coupler Motor
          ; Speed
          M203 X18000 Y18000 Z1000 E8000 C5000       	; Maximum axis speeds (mm/min)
          ; Jerk - Set maximum instantaneous speed changes (mm/min)
          M566 X500 Y500 Z500 C2 E3000               	; Maximum jerk speeds (mm/min)
          ; Endstops and probes
          ; | X |  |
          ; | Y |  |
          M574 X1 S1 P"io1.in"                		; Configure active-high endstop for low end on X via pin io1.in
          M574 Y1 S1 P"io2.in"                		; configure active-high endstop for low end on Y via pin io2.in
          M574 Z1 S2                          		; configure Z-probe endstop for low end on Z
          M574 C0										; NO Endstop for C-Coupler
          M558 P8 C"^1.io1.in" H5 F800 T10000			; set Z probe type to switch and the dive height + speeds / In Jubilee P5 but not supported on Expansion Board
          G31 P500 X0 Y0 Z2.5                 		; set Z probe trigger value, offset and trigger height
          ; Set axis software limits and min/max switch-triggering positions.
          ; Must be adjusted so that X=0 and Y=0 coordinates are at the left front corner of the print bed
          ; Axis Minima:Maxima
          M208 X-23:380 Y-13:371 Z0:320 C-45:360
          ; Define Mesh Grid and Probing Points distance
          M557 X30:360 Y15:330 P5						; define mesh grid
          ; Heaters and temperature sensors
          ; Bed
          M308 S0 P"1.temp0" Y"thermistor" T100000 B4138 A"Heizbett"                      ; configure sensor 0 as thermistor on pin 1.temp0
          M950 H0 C"1.out0" T0                                                            ; create bed heater output on 1.out0 and map it to sensor 0
          M307 H0 B0 S1.00        ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0        ; map heated bed to heater 0
          M143 H0 S140 																	; set temperature limit for heater 0 to 140C
          ; Tools - Nozzle Heater Configuration
          ; Tool 0
          M308 S1 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 1 as thermistor on pin temp0
          M950 H1 C"out0" T1                                      ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 B0 S1.00                                         ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                                ; set temperature limit for heater 1 to 280C
          ; Tool 1
          M308 S2 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 2 as thermistor on pin temp1
          M950 H2 C"out1" T2                                      ; create nozzle heater output on out2 and map it to sensor 2
          M307 H2 B0 S1.00                                         ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S280                                                ; set temperature limit for heater 2 to 280C
          ; Tool 2
          M308 S3 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 3 as thermistor on pin temp2
          M950 H3 C"out2" T3                                     ; create nozzle heater output on out3 and map it to sensor 3
          M307 H3 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
          M143 H3 S280                                               ; set temperature limit for heater 3 to 280C
          ; Tool 3
          M308 S4 P"temp3" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 4 as thermistor on pin temp3
          M950 H4 C"out3" T4                                    ; create nozzle heater output on out3 and map it to sensor 4
          M307 H4 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
          M143 H4 S280                                              ; set temperature limit for heater 4 to 280C
          ;M308 S11 Y"drivers" A"Drivers"		; defines sensor 11 as stepper driver temperature sensor / Don't work on Duet3 with Trinamic-Drivers
          ; Fans for Tool's
          ; Fans for Electronic
          ;M106 P8 C"MCU-Fan" H-1				; set fan 8 value. Thermostatic control is turned OFF
          ; Lightning on FAN Port
          M950 F9 C"2.out0" Q100				; Fan 10 (Mean the COB-LED-Stripe) is connected to 2.out0 on the second Exp_3HC Board
          M106 P9 S0.15 C"Light" H-1			; Set Fan 10 values: Start at 15% / Name in DWC / Thermostatic control turned OFF
          ; Tool definitions
          ;M563 P0 S"Tool 0" D0 H1 F5  	; Px = Tool number / Dx = Drive Number / H1 = Heater Number / Fx = Fan number print cooling fan
          ;G10  P0 R0 S0              	; Set tool 0 operating and standby temperatures / (-273 = "off")
          M563 P0 S"Tool0" D0 H1 F0                      ; define tool 0
          G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"Tool1" D1 H2 F2                      ; define tool 1
          G10 P1 R0 S0                                               ; set initial tool 1 active and standby temperatures to 0C
          M563 P2 S"Tool2" D2 H3 F4                      ; define tool 2
          G10 P2 R0 S0                                               ; set initial tool 2 active and standby temperatures to 0C
          M563 P3 S"Tool3" D3 H4 F6                      ; define tool 3
          G10 P3 R0 S0                                               ; set initial tool 3 active and standby temperatures to 0C
          ; Set extruder pressure advance
          ;M572 D0 S0.085              				; Set extruder 0 Pressure Advance to 0.085 seconds
          ;M572 D1 S0.085              				; Set extruder 1 Pressure Advance to 0.085 seconds
          ;M572 D2 S0.085              				; Set extruder 2 Pressure Advance to 0.085 seconds
          ;M572 D3 S0.085              				; Set extruder 3 Pressure Advance to 0.085 seconds
          ; Tool XYZ Offsets for each Tool
          M98  P"/sys/Toffsets.g"     				; Set tool offsets from the bed
          M575 P1 S1 B57600                                    ; enable support for PanelDue
          M501                                                             ; load saved parameters from non-volatile memory
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                              ; set voltage thresholds and actions to run on power loss
            dc42 administrators @CrazyCreator last edited by
            @crazycreator please check that the 3HC board is also running firmware 3.4, because this combination (fan connected to an expansion board and temperature sensor connected to a different board) was a known limitation of firmware 3.3. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/CAN_limitations.
            • CrazyCreator
              CrazyCreator @dc42 last edited by
                @crazycreator thanks. I've logged this as a possible bug for investigation.
                • CrazyCreator
                  @dc42 thank you ...
                    dc42 administrators @CrazyCreator last edited by dc42
                    @crazycreator I believe this is fixed in RRF 3.4.2rc2 which has been released today.
                    • CrazyCreator
                      Thanks for the tip...
                      I've already installed the update, but haven't gotten around to testing it again yet.
