    Duet 2 Thermistor shows 2000 dagrees
    • RobiiinXundefined
      RobiiinX
      ![alt text](image url)Hello,
      My current Temperature is at Tool 0 (Hotend) and Bed on 2000 dagrees. I already switch the wires but it still not work. What can i do?
      Hotend is an "3DFreunde V6 Clone)
      And Bed is an Silicone
      And where i can changes the points of probe with BLTOUCH original? in the Firmware
      here is my config.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 04 2022 20:14:28 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z800.00 E500.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z300 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F100 T2000
      G31 X19 Y0 Z0 P25; Custom settings are not defined
      M558 P9 C"^zprobe.in" H1 F1000 T9000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X45 Y0 Z2.399 ; set Z probe trigger value, offset and trigger height
      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @RobiiinX
        @robiiinx
        2000 is the reading you get when the thermistor is not connected.
          Phaedrux Moderator @RobiiinX
          @robiiinx said in Duet 2 Thermistor shows 2000 dagrees:
          Can you be more specific in what you want to do?
          Are both bed and hotend temps showing 2000c?
          How are the connected? Can you show a photo? Are you sure they are thermistors?
