    FLY RRF E3 Sapphire Pro H0 not found Error
    RepRapFirmware on other controllers
    • kolbaskinundefined
      kolbaskin
      Hi everyone
      I have an issue with my Sapphire Pro with Fly E3 RRF Board and RepRap firmware installed.
      H0 heater (bedheat) does not show up in a dashboard. When I try to heat it through console, an error "H0 not found" is showing up
      Here is my configuration file:
      ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 05 2020 19:46:54 GMT+0100 (Central European Standard Time)
      M550 P"Kolbaskin" ; set printer name
      M669 K1 ; select CoreXY mode
      M929 S1
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; disable Telnet
      M575 P1 B57600 S1 ; Turn on PanelDue/RepPanel
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      ;M350 X32 Y32 Z32 E16 I1 ; configure microstepping with interpolation
      M92 X80.30 Y80.30 Z1600.00 E392.40 ; set steps per mm
      M566 X400.00 Y400.00 Z60.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1200.00 E30000.00 ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z200.00 E1000.00 ; set accelerations (mm/s^2)
      M204 P2000 T4000 ; set acceleration for printing moves
      M906 X1200 Y1200 Z1200 E1200 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X223 Y220 Z235 S0 ; set axis maxima
      M574 X1 S1 P"!xstop"
      M574 Y2 S1 P"!ystop"
      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as PT1000 on pin bedtemp
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      ;M593 F51 ; cancel ringing at 51Hz
      ;M572 D0 S0.7
      Please help!
        jay_s_uk @kolbaskin
        @kolbaskin bedheat isn't a valid pin name
        https://teamgloomy.github.io/fly_e3_pins.html
        Should be bed or hbed
        kolbaskinundefined 1 Reply Last reply Reply Quote 0
          kolbaskin @jay_s_uk
          @jay_s_uk
          Thank you
          An issue has been solved
          • Phaedruxundefined Phaedrux moved this topic from General Discussion
