    returning a "result value" with M99
    Gcode meta commands
    • hlwerschner
      hlwerschner last edited by
      I did a search for "M98 result" and did not find something that matches. So my question is: Is there a way to receive a result from a macro execution (done via M98 P"...") back to the calling line of code?
      I imaging that this would be similar to that "iterations" variable in loops which has a very specific context and lifetime. Its use would be :
      M98 P"some-macro.g" ...
      set var.gotValue = result
      where the variable "result" is provided directly after that M98 command. It may get its value inside of the called macro "some-macro.g" when a explicit M99 is executed:
      ; this is my macro "some.macro.g" with a lot of embedded commands ...
      M99 200  ; return with "result" = 200
      I do not know if this is very complicated to implement on basis of the current RRF 3.4, but I would be even happy if I could get a simple "true" / "false" back from a M98. As far as I have understood the "abort" command, it willl kill the complete chain of macros executed and can not be used to return with a "failed" indicator to its direct calling macro?!
      • OwenD
        OwenD last edited by
        You would need to create a global variable and use that to contain whatever "result" you want your macro to return.
        if !exists(global.result)
          global result = false
        M98 P"some-macro.g"
        If you then set your global to false at the start of your macro, and true at the end of your macro, then any abort or M99 during the macro would leave the global as false indicating it didn't complete.
        ;some-macro.g
        set global.result = false
        if some_condition = true
          M99 ; cancel macro
        ;do a bunch of other stuff
        set global.result = true
        You are of course not limited to true or false.
        The global can be any format you wish.
        hlwerschner 1 Reply Last reply Reply Quote 0
        • hlwerschner
          hlwerschner @OwenD last edited by
          @owend Yes, that is the way as I am doing it now...but as I tried to state, there seems to be room for improvement 🙂
          Btw: this solutions creates a lot of global variables - in different (nested) macros - that "exist" too long , use up precious memory...and are a non-esthetic way to trivially communicate a "result" from a called macro back to the caller! So far my first msg is more of a proposal for improved meta command handling than a mere question. OK, lets wait for RRF 3.5 😉
          OwenD 1 Reply Last reply Reply Quote 0
          • OwenD
            OwenD @hlwerschner last edited by OwenD
            @hlwerschner
            I agree, a way to free globals would be good.
            What you're suggesting is analogous to having procedures and functions.
            "result" is already a reserved word but I can see the usefulness in what you propose.
            Perhaps a new post in firmware wish list is in order.
              dc42 administrators @hlwerschner last edited by
              @hlwerschner I will add this to the work list for RRF 3.5.
