DWC Seems to Crash After Uploading a Print
@phaedrux said in DWC Seems to Crash After Uploading a Print:
If you downgrade to 3.3 does it persist? It would be useful to know if it's tied to the firmware or the hardware.
Okay, I flashed back to 3.3 and the problem persists.
This is really odd, because I have a number of larger files uploaded already without that issue. So, it started recently.
No changes to me network or the printer. I'm stumped at the moment.
A wireshark trace could maybe show where the problem is.
Is there a way for DWC to gather detailed logs?
These are your options for logging but I don't know if it will capture what is happening.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Logging
A wireshark trace would at least tell us where the connection is failing.
@ccs86 I've been seeing similar with DWC after going to 3.4.0. There is some real weird behavior in the UI now with resets, reconnections, crashes on saving big macros/config files, etc... Very frustrating.
@clegg78 said in DWC Seems to Crash After Uploading a Print:
Interesting.
I never noticed this issue before going to the release version of 3.4.0.
I tried flashing back to earlier versions of DWC, but I left RRF at 3.4.0. So, maybe there is actually an issue with RRF that is causing the DWC disconnects.
@ccs86 So... I may have stumbled on something in my case today... Disabling both filament sensors (Duet rotating magnet ones, one on each print head) = no reconnections/DWC crashes.
Enabling one = some random drops.
Enabling both = Crashes galore.I am going to be doing more testing on this.
I'm actually using no filament sensors. Just a BL Touch.
@ccs86 Interesting. I also have a BLTouch. curious what bug was introduced in 3.4.0 to cause these weird behaviors.
Have you tried downgrading RRF? That's my next step.
@ccs86 I have not. My machine is used for pretty consistent production use and the DWC thing is annoying, very annoying, but hasn't been a show stopper for it to run. And the code/config tweaks for 3.4.0 I don't want to unwind. I guess if it turns out there is no fix, I may have to go back.
@ccs86 is this still on Duet Maestro?
@dc42 Yes
@ccs86 please provide your config.g file and any other macro files that it calls.
; Configuration file for Duet Maestro (firmware version 3) ; General preferences G90 ; absolute coordinates M83 ; relative extruder M550 P"Maestro86" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; drive 0 goes backwards M569 P1 S1 ; drive 1 goes forwards M569 P2 S0 ; drive 2 goes backwards M569 P3 S0 ; drive 3 goes backwards M569 P0 D2 ;D3 V468 ; X Stealthchop2 till about 10 mm/sec M569 P1 D2 ;D3 V468 ; Y Stealthchop2 till about 10 mm/sec M569 P2 D3 V40 ; Z Stealthchop2 till about 46.9 mm/sec M569 P3 D2 ; Extruder in Spreadcyle M584 X1 Y0 Z2 E3 ; Drive mapping M92 X160.0 Y160.0 Z401.5 E695 ; Steps per mm M350 X16 Y16 Z16 E16 I1 ; Microstepping with interpolation M201 X5000.00 Y5000.00 Z230.00 E2500.00 ; Max accelerations (mm/s^2) M203 X12000.00 Y12000.00 Z2100.00 E2400.00 ; Max speeds (mm/min) M204 P2500 T4000 ; Accelerations (mm/s^2) ;M205 X12 Y12 Z3 E4.5 ; Maximum jerk rates (mm/s) M566 X600 Y600 Z180.0 E270 P1 ; Maximum jerk rates (mm/min) M593 P"MZV" F40.5 ; Input Shaping M572 D0 S0.032 ; Pressure Advance M906 X1300 Y1300 Z1400 E490 I50 ; Motor currents (mA) and motor idle factor M84 S30 ; Idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Axis minima M208 X195 Y180 Z220 S0 ; Axis maxima ; Endstops M574 X1 S1 P"!xstop" ; Active-high endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; Active-high endstop for low end on Y via pin !ystop ; Z-Probe M574 Z1 S2 ; Z endstop controlled by probe M558 P5 C"^zprobe.in" H5 F500 T6000 A1 ; Z probe type to bltouch and the dive height + speeds M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch G31 P25 X20 Y-14 Z.98 ; Z probe trigger value, offset and trigger height M557 X20:195 Y0:166 S18.8 ; define mesh grid M376 H1.5 ; mesh taper ;Accelerometer M955 P0 C"twck0+twd0" R12 ; Heaters M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as a PT100 sensor in the first position on the Duet 2 daughter board connector M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for bed heater 0 M308 S1 P"e0temp" Y"pt1000" ;T100000 B4725 C7.06e-8 ; configure sensor 1 as PT1000 on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S243 ; set temperature limit for nozzle heater 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper ; Heater model parameters ;Bed ;M307 H0 R0.194 C896.8 D2.07 S1.00 ;M307 H0 R0.190 K0.196:0.000 D2.03 E1.35 S1.00 B0 M307 H0 R0.190 K0.174:0.000 D1.95 E1.35 S1.00 B0 ;Hotend ;M307 H1 R2.523 C231.0:134.5 D5.90 S1.00 V24.3 ;M307 H1 R2.324 K0.389:0.146 D3.76 E1.35 S1.00 B0 V24.3 M307 H1 R2.459 K0.398:0.160 D3.91 E1.35 S1.00 B0 V24.3 ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 B1.5 X180 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" ;Q800 ; create fan 2 on pin fan2 and set its frequency M106 P2 H1:2:3 L1 X1 T53 ; set fan 2 value ; Tools M563 P0 S"E0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M595 P40 T0 ; select first tool -
Do you need anything else @dc42 ?
Does 3.4.1 have any potential improvements for this issue?
@ccs86 said in DWC Seems to Crash After Uploading a Print:
I'm not sure, but worth testing with the latest code base regardless.
