    Solved AKC LP - calibration woes
    • Jbenj00
      Jbenj00 last edited by
      I converted my delta over to duet 2 wifi, smart effector, mag ball arms. I ran delta calibration and followed to documentation. I ran it 6 times and kicks out deviation of -0.000 , 0.017 +/- .05 on the latter. I ran mesh bed leveling to see what it looks like and it is not good. I then went back and set my probe offset to 0 and measured the trigger height of each point in delta calibration and offset those points z in bed.g . and it did not change my mesh much at all but at least it is consistently probing those areas correctly. any help guidance is appreciated! Please see below my mesh's I ran 4 times and they are identical, and my config / bed.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 14 2022 17:05:41 GMT-0400 (Eastern Daylight Time)
      M550 P"AKC Delta" ; set printer name
      M665 R140.125 L288.17 B115 H230.46 X 0.986° Y 2.410° ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.04 Y-.18 Z.14 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S0 ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E4 ; set drive mapping
      M350 E16 I0 ; Disable interpolation on extruder
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation for XYZ
      M92 X80.00 Y80.00 Z80.00 E96.00 ; set steps per mm
      M566 X300.00 Y300.00 Z300.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X750.00 Y750.00 Z750.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M558 P8 C"zprobe.in+zprobe.mod" H5 F120 r.4 T10000 B1 ; set Z probe type to unmodulated and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P100 X0 Y0 Z-0.21 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      ;M307 H0 B0 R0.325 C444.4 D5.28 S1.00 V23 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H0 R0.314 C404.133:404.133 D7.24 S1.00 V23.7 B0 I0
      M143 H0 S75 ; set temperature limit for heater 0 to 120C
      ;M307 H1 B0 R5.298 C198.6:198.6 D10.28 S1.00 V23.6 ; disable bang-bang mode for heater and set PWM limit
      ;M307 H1 R5.502 C178.573:138.507 D9.45 S1.00 V23.6 B0 I0
      ;M307 H1 B0 R5.883 C199.7:138.1 D9.56 S1.00 V23.5
      M143 H1 S265 ; set temperature limit for heater 1 to 265C
      m501
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 14 2022 17:05:40 GMT-0400 (Eastern Daylight Time)
      ;G28 ; home all towers
      ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y84.9 H-.04 Z-99999
      G30 P1 X73.53 Y-42.45 H-.05 Z-99999
      G30 P2 X-73.53 Y-42.45 H-.22 Z-99999
      G30 P3 X0 Y42.4 H-.01 Z-99999
      G30 P4 X36.72 Y-21.2 H-.02 Z-99999
      G30 P5 X-36.72 Y-21.2 H-.06 Z-99999
      G30 P6 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      • Jbenj00
        quick update - I made a new bed.g with more points s6 and ran calibration once and then ran a mesh and this was the result.
        ; bed.g file for RepRapFirmware, generated by Escher3D calculator
        ; 13 points, 6 factors, probing radius: 112, probe offset (0, 0)
        G28
        G30 P0 X0.00 Y112.00 Z-99999 H0
        G30 P1 X71.99 Y85.80 Z-99999 H0
        G30 P2 X110.30 Y19.45 Z-99999 H0
        G30 P3 X96.99 Y-56.00 Z-99999 H0
        G30 P4 X38.31 Y-105.25 Z-99999 H0
        G30 P5 X-38.31 Y-105.25 Z-99999 H0
        G30 P6 X-96.99 Y-56.00 Z-99999 H0
        G30 P7 X-110.30 Y19.45 Z-99999 H0
        G30 P8 X-71.99 Y85.80 Z-99999 H0
        G30 P9 X0.00 Y56.00 Z-99999 H0
        G30 P10 X48.50 Y-28.00 Z-99999 H0
        G30 P11 X-48.50 Y-28.00 Z-99999 H0
        G30 P12 X0 Y0 Z-99999 S6
        • Jbenj00
          Jbenj00 last edited by Jbenj00
          okay, I think I solved my own problem. But any feedback or input is welcomed, good or bad. So first I bumped my bed.g probe from 7 to 13 points s6 which took my mesh deviation from .174 to .054 and min/max from -.512/.363 to -.140/.114
          NOTE: I am using a boro bed and have put a straight edge across it with a light it is "almost" perfectly flat. I am very happy with the results
          With that I went all in, adjusting my bed.g probe point amounts / from s6-8
          bed.g 13 points @ 112radius 6 factor
          g29 - 61 points probed, min error -0.140, max error 0.114, mean 0.004, deviation 0.054
          m666 Endstop adjustments X1.59 Y-2.48 Z0.89, tilt X0.00% Y0.00%
          m665 Diagonals 288.000:288.000:288.000, delta radius 139.404, homed height 230.635, bed radius 110.0, X 0.321°, Y 0.112°, Z 0.000°
          bed.g 16 points @110 radius 6 factor
          G29 61 points probed, min error -0.078, max error 0.078, mean -0.001, deviation 0.036
          m666 Endstop adjustments X1.64 Y-2.37 Z0.73, tilt X0.00% Y0.00%
          m665 Diagonals 288.000:288.000:288.000, delta radius 139.543, homed height 230.643, bed radius 110.0, X 0.479°, Y 0.073°, Z 0.000°
          bed.g 16 points @110 radius 8 factor
          G29 61 points probed, min error -0.053, max error 0.064, mean 0.007, deviation 0.023
          m666 Endstop adjustments X1.38 Y-1.34 Z-0.03, tilt X0.59% Y-0.70%
          m665 Diagonals 288.000:288.000:288.000, delta radius 139.487, homed height 230.644, bed radius 110.0, X -0.051°, Y 0.098°, Z 0.000°
          EDIT: Just ran my first test print - the first layer...perfect all the way around the bed. 1aa630b6-ea0f-4f37-9629-598850fd5c25-image.png
          dc42 1 Reply Last reply Reply Quote 2
            dc42 administrators @Jbenj00 last edited by dc42
            @jbenj00 I'm glad you got it working well! I use 13 probe points and S8 on the final G30 command in bed.g. The reported deviation is around 0.02mm. I don't normally use mesh compensation because the height map is very flat, like yours.
            Jbenj00 1 Reply Last reply Reply Quote 1
            • Jbenj00
              Jbenj00 @dc42 last edited by
              @dc42 I am happy too, thank you! I had been bouncing my head off a wall and digging through the forums looking for so guidance before I posted. Then after I said let's give this a shot and dumb luck won the day. I was only using mesh as a tool to see what my delta calibration was effecting.
              • Topic has been marked as a question  dc42 dc42
              • Topic has been marked as solved  dc42 dc42
