    Solved Config.g file for CNC Application with dual Y drives Question
    • JADoglio
      JADoglio last edited by JADoglio
      I created this Duet 3 (latest version) config.g file using RRF configurator in custom mode for the CNC machine I am building. I removed the commands related to heaters and extruders as there are none in a CNC router and the machine only has one fan and that is used to cool the control box. The machine has two Y axis drive motors and I would like them both to be controlled with one end stop. I assigned the second Y axis to the E0 pins and I would like to know if this file is properly set up to control both Y axis with the io1.in end stop. If anyone has any comments on anything else in this file please comment on that as well. Thanks
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Apr 19 2022 16:45:47 GMT-0400 (Eastern Daylight Time)
      M550 P"Jim’s Duet 3" ; set printer name
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 E0.3 Z0.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X800 Y800 Z800 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Left Y via pin io1.in
      M574 E0 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Right Y via pin io1.in
      M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M563 P0 S"Router" D0 ; define tool 0
      G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets; set initial tool 0 active and standby temperatures to 0C
      T0 ; select first tool
        Phaedrux Moderator @JADoglio last edited by
        @jadoglio said in Config.g file for CNC Application with dual Y drives Question:
        You're trying to use the same pin for two endstops here.
        If you send M98 P"config.g" to check for syntax errors it will likely complain.
        If you have two motors for Y each with their own drivers and you want to use them both for the Y axis you need to specify that in the M584 command. Such as M584 Y0.1:0.3 That tells it that Y axis is made up of drivers 1 and 3 together.
        For the endstop, if you only have a single one, you just need to define it for the Y axis and that's it. It will stop both motors when the endstop is triggered.
        So remove this line entirely
        JADoglio 1 Reply Last reply Reply Quote 0
        • JADoglio
          JADoglio @Phaedrux last edited by
          @phaedrux Thank You that is exactly what I needed to know. Appreciate the help.
          • Topic has been marked as a question  Phaedrux Phaedrux
          • Topic has been marked as solved  Phaedrux Phaedrux
