    strange UVW axis behaviour compared to ABC axis
    • Tricep terryundefined
      Tricep terry
      Hi I'm not using duet as a printer but rather write my own Gcode scripts to move certain axis. Now I came across something strange in the behaviour of ABC axis compared to XYZUVW axis.
      I have the same exact settings for the ABC axis and UVW axis, however, if i ran the following code :
      M118 S"Start"
      G91 G1 A-170.00 B-80.00 C-234.00 D-16.0 F361 ;
      M400
      M118 S"finished"
      It takes exactly 50 seconds as it should.
      however if I change it to :
      M118 S"Start"
      G91 G1 A-170.00 B-80.00 C-234.00 U-16.0 F361 ;
      M400
      M118 S"finished"
      it takes about 1 to 2 seconds.
      My guess would be that this has to do with the "cartesian style" mentioned in the config.json file.
      The same thing happens for the V and W axis...
      Kind regards,
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Tricep terry
        @tricep-terry Hello, I guess it has to do with ABCD being default rotational and UVW being linear axes:
        https://duet3d.dozuki.com/Wiki/M584
        R parameter: " then RRF 3.2beta3 and later assume UVW are linear and ABCD are rotational."
        Tricep terryundefined 1 Reply Last reply Reply Quote 0
          Tricep terry @JoergS5
          @joergs5 That might be it, how should I modify the M584 command then? Should I create a separate M584 line for each axis?
          Kind regards,
          Max
          JoergS5undefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            @tricep-terry I have no experience, but in my interpretation, R0 and R1 settings should be in separate lines and commands.
            I would also set speeds for the letters. (Being degrees/min for rotational).
            • JoergS5undefined
              @tricep-terry there is an addional possible reason, but it has to do with U as linear also: the total speed is calculated and limited in the kinematics code. It depends on the distance calculated, which is calculated for rotational and linear axes separately. So A+B+C+D all rotational with D low limits the total speed, but A+B+C rotational + D linear with A,B,C high values do not limit total speed. But this will be fixed by specifying U as rotational, also.
                @joergs5 Hi, your suggestion worked. I changed the S value in the M584 command and now it works. Thanks!
                Kind regards,
                • JoergS5undefined
                  @tricep-terry that's good news, thanks for telling!
                  • dc42undefined dc42 marked this topic as a question
