    BL-Touch to Alfawise U10
    970
    • Perttiundefined
      Pertti @Phaedrux
      @phaedrux
      I´ll check this, looks good. https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Mar 06 2022 15:03:52 GMT+0200 (Itä-Euroopan normaaliaika)
      G91 ; relative positioning
      G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-505 F360 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
      G1 H1 Z-505 F1800 ; move Z down until the endstop is triggered
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
        Phaedrux Moderator @Pertti
        @pertti said in BL-Touch to Alfawise U10:
        Remove those lines in homeall and replace them with
        G90
        G1 X150 Y150
        G30
        And in homez, remove those lines and replace them with the same.
        Perttiundefined 1 Reply Last reply Reply Quote 0
        • Perttiundefined
          Pertti @Phaedrux
          Thank You all! First testprints going on! So far so good. I removed the z endstop and replaced it with z-probe.
          Pertti
