    Duet3 problem sensor homing, not happen in Duet2
    Using Duet Controllers
    159
    • FBG
      FBG last edited by
      Hello everybody!
      i am user of a lot Duet2Ethernet boards with Expansion Breakout.
      All is ok.
      Now I start with my first Duet 3 Mainboard 6HC v1.01A with severals Duet 3 Expansion Board 1XD and with raspberry.
      Everything was config perfectly and all works well, now the WebInterface is really fast!!
      My unique problem is:
      When I do homing...90%times while the axis (indifferent) move to find the sensor...the axis stop because think that the sensor was triggered....
      It always starts to move and when it moves a few cm it stops...as if the sensor had been found!!
      I use a simple sensor switch, tested with NC or NO. I use a good brand wires crossed shielded.
      I use this config:
      M574 X1 S1 P"!io3.in"
      M574 Y1 S1 P"!io7.in"
      Also I tested:
      M574 X1 S1 P"^!io3.in"
      M574 Y1 S1 P"^!io7.in"
      Also I has tested without raspberry and I test with 3.3.0 and 3.4.0 firmware version.
      Today I install a duet2Ethernet, with 3.3.0 and 3.4.0 firmware.
      Everything is absolutely perfect 100% times.
      What happen?? Any idea?
      Best Regards
        Remove the !
        FBG 1 Reply Last reply Reply Quote 0
        • FBG
          FBG @Phaedrux last edited by
          @phaedrux I think that I don't explain well....
          I must use ! if the sensor is in NO, and not use if the sensor is in NC..
          As I said, I tested in NO and NC, with same results
          The problem is not that the start to move in opposite direction...start to move in right direction but WHILE is moving to find the sensor...STOP! as the sensor has been triggered! but the sensor is not triggered!
          Best Regards
          Stephen6309 1 Reply Last reply Reply Quote 0
          • Stephen6309
            Stephen6309 @FBG last edited by
            @fbg What does M119 show? It should be untriggered when the endstop is unpressed.
            • FBG
              FBG @Stephen6309 last edited by
              @stephen6309 If I send M119 without press any home sensor:
              Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
              If I send M119 with X sensor pressed:
              Endstops - X: at min stop, Y: not stopped, Z: not stopped, Z probe: not stopped
              Same result with others sensors
              Everything is normal....
              Ideas?
              Bes Regards
                Is the switch actually functional?
                Do you have continuity on the wiring?
                • FBG
                  FBG @Phaedrux last edited by FBG
                  @phaedrux The sensors are news and perfect, also I changed for a new and happen the same.
                  Remember @Phaedrux IF I test with a duet2Ethernet ALL works properly.
                  Today I checked that show in "Objet Model->sensors->endstop", if when the axis move and stop the triggered say "yes"...
                  I can confirm that when the axis stop before touch the sensor I don't see TRUE, all time say FALSE.
                  So, if say FALSE all time, because STOP???
                  Firmware problem?
                  Duet3 Hardware problem?
                  Best Regards
                    Post your config.g and your homing files. Perhaps you have the homing move shorter than the axis length.
                    @fbg said in Duet3 problem sensor homing, not happen in Duet2:
                    This makes me think you've wired it incorrectly. Photo?
