Temperature sensor error message
Using Duet Controllers
  • undefined
    geon han_Kang
    Hello.
    I'm making two printers, but I'm inquiring because there's a problem.
    A heater temperature reading error message appears and continues to interrupt while one printer is leveling the G29 bed.
    However, temperature sensor sensing works well without errors.
    I wonder what caused this.
    • undefined
      Have you PID tuned the heater?
      Can you control the heater by setting a temp? Does it rise and maintain as expected?
      Can you post your config.g and the results of M122 and M98 P"config.g"?
      What kind of heater and thermistor is it?
      undefined 1 Reply Last reply 21 Apr 2022, 07:50 Reply Quote 0
      • undefined
        geon han_Kang @Phaedrux
        @phaedrux Thank you for your answer 🙂
        You can control the heater by setting the temperature. It rises as expected.
        I don't know exactly what kind of heater and thermistor are, but I think it's 1000K 24V.
        M122
        RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956BA-NA3TN-6JTDG-3S86S-TUB2S
        Used output buffers: 1 of 40 (10 max)
        Static ram: 150904
        Dynamic ram: 61604 of which 0 recycled
        Never used RAM 141684, free system stack 219 words
        Tasks: SBC(ready,20.8%,326) HEAT(delaying,0.1%,325) Move(notifyWait,0.2%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,30.5%,93) MAIN(running,48.4%,1252) IDLE(ready,0.0%,29), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 06:15:47 ago, cause: software
        Last software reset at 2022-04-15 08:05, reason: User, none spinning, available RAM 141468, slot 2
        Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
        Error status: 0x00
        Step timer max interval 132
        MCU temperature: min 48.3, current 48.7, max 55.6
        Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
        Driver 0: position 0, standstill, reads 38330, writes 11 timeouts 0, SG min/max 0/0
        Driver 1: position 0, standstill, reads 38324, writes 17 timeouts 0, SG min/max 0/0
        Driver 2: position 0, standstill, reads 38324, writes 17 timeouts 0, SG min/max 0/0
        Driver 3: position 0, standstill, reads 38324, writes 17 timeouts 0, SG min/max 0/0
        Driver 4: position 0, standstill, reads 38324, writes 17 timeouts 0, SG min/max 0/0
        Driver 5: position 0, standstill, reads 38324, writes 17 timeouts 0, SG min/max 0/0
        Date/time: 2022-04-15 14:21:00
        Slowest loop: 63.36ms; fastest: 0.04ms
        === Storage ===
        Free file entries: 10
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters = -1 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 202923, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 112740/0/0
        Tx timeouts 0,0,112739,0,0,90182 last cancelled message type 4514 dest 127
        === SBC interface ===
        State: 4, failed transfers: 0, checksum errors: 0
        Last transfer: 1ms ago
        RX/TX seq numbers: 56802/56802
        SPI underruns 0, overruns 0
        Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.3.0
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz
        Full transfers per second: 34.49, max wait times: 6.4ms/0.0ms
        Codes per second: 0.00
        Maximum length of RX/TX data transfers: 2868/804
        undefined 1 Reply Last reply 21 Apr 2022, 07:51 Reply Quote 0
        • undefined
          geon han_Kang @geon han_Kang
          M308 S0 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out2" T0 Q1 ; create heater output on out0 and map it to sensor 0 ; disable bang-bang mode for heater and set PWM limit
          M143 H0 S70 ; set temperature limit for heater 0 to 70C
          M140 P1 H0
          undefined 1 Reply Last reply 21 Apr 2022, 08:14 Reply Quote 0
          • undefined
            deckingman @geon han_Kang
            @geon-han_kang The error message refers to heater 2 sensor being open circuit. You haven't yet posted your config.g file so it's hard to say what the problem is but looking at the screen shot, my best guess is that you have associated heater 2 with tool 0 but without first configuring heater 2. Please post your complete config g file and your config-override.g if you use it.
            undefined 1 Reply Last reply 21 Apr 2022, 09:28 Reply Quote 0
            • undefined
              geon han_Kang @deckingman
              @deckingman
              Should I connect the tamp0 to tool0?;(
              ; generated by RepRapFirmware Configuration Tool v3.2.2 on Tue Jan 26 2021 16:38:54 GMT+0100 (Central European Standard Time)
              M550 P"CONCEPTION" ; set printer name
              ;M551 P"Macarena88" ; set password
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S1 ; physical drive 0.0 goes forwards
              M569 P1 S1 ; physical drive 0.1 goes forwards
              M569 P2 S1 ; physical drive 0.2 goes forwards
              M569 P3 S0 ; physical drive 0.3 goes forwards
              M569 P4 S0 ; physical drive 0.3 goes forwards
              M569 P5 S0 ; physical drive 0.3 goes forwards
              M584 X5 Y1:2 Z3 E4 ; set drive mapping
              M92 X80.00 Y80.00 Z400.00 E492.45 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E800.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X15000.00 Y15000.00 Z400.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
              M906 X1400 Y2500 Z2500 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-25 Y-72 Z0 S1 ; set axis minima
              M208 X1020 Y500 Z500 S0 ; set axis maxima
              M574 X1 S1 P"^!io0.in" ; configure active-high endstop for low end on X via pin io0.in
              M574 Y1 S1 P"^!io1.in" ; configure active-high endstop for low end on Y via pin io1.in
              M574 Z1 S1 P"^!io2.in" ; configure active-high endstop for low end on Z via pin io2.in
              M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
              M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X-30 Y-2 Z3.3 ; set Z probe trigger value, offset and trigger height
              M557 X20:980 Y10:490 S120 ; define mesh grid
              M140 P1 H0
              M308 S2 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M950 H2 C"out3" T2 ; create heater output on out1 and map it to sensor 1 ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H2 S350 ; set temperature limit for heater 1 to 70C
              M307 H0 A200.8 C850.6 D2.0 S1.00 V24.0 B0
              M307 H2 A491.0 C185.5 D4.9 S1.00 V24.0 B0
              M950 F0 C"out8" Q255 ; create fan 0 on pin out4 and set its frequency
              M106 P0 S0.7 L0.3 X0.7 H-1 ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"out7" Q200 ; create fan 1 on pin out5 and set its frequency ; set fan 1 value. Thermostatic control is turned on
              M106 P1 S0.7 L0.3 X0.7 H2
              M563 P0 D0 H2 F0 ; define tool 0
              //config-override.g//
              ; config-override.g file generated in response to M500 at 2021-01-27 15:58
              ; Heater model parameters
              ; Workplace coordinates
              G10 L2 P1 X0.00 Y0.00 Z0.00
              G10 L2 P2 X0.00 Y0.00 Z0.00
              G10 L2 P3 X0.00 Y0.00 Z0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00
              undefined 1 Reply Last reply 21 Apr 2022, 20:39 Reply Quote 0
              • undefined
                Phaedrux Moderator @geon han_Kang
                @geon-han_kang said in Temperature sensor error message:
                It's complaining that this does not match the Pi hostname.
                As for the open circuit error I think you may have an intermittent wiring break.
                4 out of 7
