    Filament sensor problem after upgrade to 3.2
    Filament Monitor
    117
    • Alijambo73
      Alijambo73 last edited by
      I have a Corexy with 4 extruders. After the upgrade to 3.2 I'm having a problem where if I run M591 D0 it shows filament is present but when I start a print it pauses and says no filament detected E0. It worked fine before the upgrade.
      I have this in my config.g "M591 D0 P1 C"e0stop" S1". I can't figure it out. I have read some references to error,g but I'm not sure what that is or if it would be related? Do I need this or is my original pause .g sufficient?
      Any thoughts on the filament sensor not detecting filament after the heaters reach temp and clarification on error.g would be welcomed.
        What version were you running before updating to 3.2?
        Why did you stop at 3.2 when 3.4 is out now?
        Please post your config.g and the results of M122 and M98 P"config.g" as well.
        Alijambo73 1 Reply Last reply Reply Quote 0
        • Referenced by  Phaedrux Phaedrux
        • Alijambo73
          Alijambo73 @Phaedrux last edited by
          @phaedrux I was running 2.03. I was forced to upgrade when my original board died and the replacement I received had 3.2. I have just been making all the changes to my config and this is (as far as I can tell) the only problem.
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 0JD0M-9P6B2-NJ4S4-6JKDA-3S86K-KB16L
          Used output buffers: 3 of 24 (21 max)
          Static ram: 23460
          Dynamic ram: 73964 of which 96 recycled
          Never used RAM 14560, free system stack 182 words
          Tasks: NETWORK(ready,155) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,419) IDLE(ready,20)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:07:01 ago, cause: power up
          Last software reset at 2022-04-20 20:03, reason: User, GCodes spinning, available RAM 14608, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 18.3, current 25.2, max 25.8
          Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, standstill, SG min/max not available
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-04-21 00:11:22
          Cache data hit count 510608225
          Slowest loop: 4.43ms; fastest: 0.22ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 6.0ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 23.78ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(1) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address 48:3f:da:a6:83:44
            WiFi Vcc 3.46, reset reason Power up
            WiFi flash size 2097152, free heap 23296
            WiFi IP address 192.168.1.221
            WiFi signal strength -67dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            Socket states: 0 4 2 0 0 0 0 0
            === Filament sensors ===
            Extruder 0 sensor: ok
            === DueX ===
            Read count 1, 0.14 reads/min
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: in file macro line 121 column 55: M911: control character in string
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 608C
          config.g
          dc42 Phaedrux 2 Replies Last reply Reply Quote 0
          • Alijambo73
            Sorry I didn't think this post went through.
              dc42 administrators @Alijambo73 last edited by
              @alijambo73 what type of filament sensor is it?
                Phaedrux Moderator @Alijambo73 last edited by
                @alijambo73 said in Filament sensor problem after upgrade to 3.2:
                This error seems to be due to a missing closing quotation mark at the end of your M911 command.
                ;Power Fail Recovery
                M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000
                Do you still have the config.g file from your previous 2.03 board?
                I think it would be a good idea to update to the most recent firmware as well.
                If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
                That will get your firmware and DWC up to date.
                • Alijambo73
                  Alijambo73 @dc42 last edited by
                  @dc42 Traingle labs. I think I solved it thanks to this post I found today.
                  https://forum.duet3d.com/topic/21610/installing-trianglelab-filament-sensor-fb
                  The 1k resistor seems to have solved the problem.
                  • Alijambo73
                    @phaedrux Will I need to make any config changes?
                      Not likely.
