    Problem with simple sensor after upgrade
    Filament Monitor
    • Alijambo73
      Alijambo73 last edited by
      I have a Corexy with 4 extruders. After the upgrade to 3.2 I'm having a problem where if I run M591 D0 it shows filament is present but when I start a print it pauses and says no filament detected E0. It worked fine before the upgrade.
      I have this in my config.g "M591 D0 P1 C"e0stop" S1". I can't figure it out. I have read some references to error,g but I'm not sure what that is or if it would be related? Do I need this or is my original pause .g sufficient?
      Any thoughts on the filament sensor not detecting filament after the heaters reach temp and clarification on error.g would be welcomed.
        One thread is enough. https://forum.duet3d.com/topic/28243/filament-sensor-problem-after-upgrade-to-3-2
        • Locked by  Phaedrux Phaedrux
