    Bed PID tuning and M307 settings
    Firmware installation
    • Aurimasundefined
      Aurimas
      Hi guys,
      I am pulling my hair out.
      Duet3 Mini 5+ board - makes no difference
      I have big bed that takes time to heat up.
      fairly slow. it bombs out when heating.
      I run PID tune. It gives the result, but complains that it was inconsistent.
      see below:
      Warning: heater behaviour was not consistent during tuning Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 3341 seconds. This heater needs the following M307 command: M307 H0 R0.246 K0.857:0.000 D2.04 E1.35 S1.00 B0 Send M500 to save this command in config-override.g
      I add the settings into the config and straightaway it gives me an error when I am trying to heat it up
      Error: Heater 0 fault: temperature rising too slowly: expected 2.18°C/sec measured 0.22°C/sec.
      I tried changing R and D values - makes no difference at all. Expected rise value is still the same and always gives me an error.
      do you guys have any ideas?
      Australian design and build large scale 3d printers
      https://aurarum.com.au
      Phrayzurundefined 1 Reply Last reply Reply Quote 0
      • Phrayzurundefined
        Phrayzur @Aurimas
        @aurimas I've been having the same problem... Check this post out...
        https://forum.duet3d.com/topic/28218/cr-10s-heated-bed-error-temp-rising-too-slowly
        Aurimasundefined 1 Reply Last reply Reply Quote 0
          How big is the bed? How powerful is the heater?
          What values did you try for D?
          • Aurimasundefined
            Aurimas @Phaedrux
            @phaedrux as I said in the description - it is big. But it doesn't matter. After PID tune it should respond properly, but it doesn't. And that's the problem.
            I have tried R values from 0.001 to 5 and D from 0.5 to 100.
            The expected rise value is not changing and that is the problem
            • Aurimasundefined
              Aurimas @Phrayzur
              @phrayzur not related. I have done PID tune already - no good
