    Duet3 + Mini 5 X Y sensorless homing issue
    • moth4017
      moth4017 last edited by moth4017
      Core X,Y, Duet3+mini 5 ,
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode)
      If i home X before Y it works perfectly , X will home perfectly , if i then try to home Y it will only move about 1mm and then stops.
      if i Home Y before X , Y homes but with more of a "thud" than X did which is odd. if i then try to home X , it homes but also moves slightly in the Y direction.
      if i move X or Y manually using DWC they all work perfectly.
      G90                                            	; send absolute coordinates...
      M83                                            	; ...but relative extruder moves
      M550 P"Valkyrie 3030 V001"                     	; set printer name
      M669 K1     									; core xy
      M552 S1                                        	; enable network
      M586 P0 S1                                     	; enable HTTP
      M586 P1 S0                                     	; disable FTP
      M586 P2 S0                                     	; disable Telnet
      M569 P0.0 S1	D3 V10							; physical drive 0 goes forwards
      M569 P0.1 S1    D3 V10                          ; physical drive 1 goes forwards
      M569 P0.2 S1                                 	; physical drive 2 goes forwards ( blown needs replacing)
      M569 P0.3 S1                                	; physical drive 3 goes forwards (extruder
      M569 P0.4 S1  	D3 	V50                        	; physical drive 4 goes forwards D3=stealthchop
      M569 P0.5 S0  	D3 	V50							; physical drive 5 goes backwards
      M569 P0.6 S1  	D3	V50							; physical drive 6 goes forwards
      M584 X1 Y0 E3 Z0.4:0.5:0.6               		; set drive mapping FL,FR,RC
      M350 X16 Y16 I1                       			; configure microstepping with interpolation
      M350 Z16 E16 I1
      M92 X80.00 Y80.00  Z320.00  E260.00           	; set steps per m
      M566 X500.00 Y500.00 Z800.00 E100.00 P1        	; set maximum instantaneous speed changes (mm/min)
      M203 X8000.00 Y8000.00 Z1000.00 E400.00     	; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z200.00 E250.00       	; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E600 I10                ; set motor currents (mA) and motor idle factor in per cent
      M84 S20                                        	; Set idle timeout
      M208 X0 Y0 Z0 S1                             	; set axis minima "Travel Area"
      M208 X270 Y240 Z405 S0                         	; set axis maxima "Travel area"
      ;M574 X1 S1 P"!io0.in"                        	; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 X1 S4   									; configure sensorless endstop, 1 = low end, 2 = high end. S4 multipule motors
      ;M574 Y2 S1 P"!io1.in"
      M574 Y2 S4 										; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      ;M574 Z2 S2 P"!io4.in" 							; != invert signal
      M574 Z2 S4                              		; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
      M671 X-34.4:296:132.5 Y0:0:296 S25 				; leadscrews at front left,front right, rear Center s= max correction factor  must be in same order as M584
      M558 P8 C"!io3.in" H5 F600 T18000 A30 S0.03     ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 Z0.6									; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
      G31 P500 X26 Y6               					; set x,y trigger value, offset and trigger height
      M557 X30:270 Y10:250 S40                     	; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950  A"Bed T °C" 		; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"out0" T0    Q10                      					; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.140 K0.103:0.000 D43.19 E1.35 S0.90 B0				; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
      M140 H0                                       					; map heated bed to heater 0
      M143 H0 S120                                   					; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4267  A"Extruder T °C" 	; configure sensor 1 as thermistor on pin e0temp (104gt2)
      M950 H1 C"out1" T1                           					; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R3.435 K0.348:0.274 D6.64 E1.35 S1.00 B0 V23.9			; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   					; set temperature limit for heater 1 to 280C
      ; Custom code
      M308 S2 P"temp2" Y"thermistor" T300000 B4562  A"Chamber T °C" 	; configure sensor 1 as thermistor on pin e0temp (104gt2)
      M308 S3 Y"Stepper-temp" A"Stepper Motor"						; configure sensor 3 as stepper motor temperature sensor
      M950 F0 C"out4" Q500 C"Part Fan" 				; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1									; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out3" Q500 C"Extruder Fan"			; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45								; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                             	; define tool 0
      G10 P0 X0 Y0 Z0                               	; set tool 0 axis offsets
      G10 P0 R0 S0                                  	; set initial tool 0 active and standby temperatures to 0C
      T0
      M98 P"/macros/3zhome"
      M400                                        ; make sure everything has stopped before we make changes
      G91                                  		; relative positioning
      M915 P0.0:0.1 S1 H200 F0 R1                 ; Configure Stall Detection
      M906 X400	; Lower motor current by 300mA
      G1 H2 X0.2 F3000    				; power up motors to ensure they are not stalled
      G4 P100                  			; wait 100ms
      M400
      M574 X1 S4
      G1 F9000
      G1 H1 X-350                           		; Home x-Axis actuators independently
      M906 X1000							           			; Reset motor current
      G90                                  		; absolute positioning
      M906 Y400	; Lower motor current by 300mA
      G1 H2 Y0.2 F3000    				; power up motors to ensure they are not stalled
      M400
      M574 Y2 S4
      G1 F9000
      G1 H1 Y350                           		; Home y-Axis actuators independently
      Aurimas 1 Reply Last reply Reply Quote 0
      • Aurimas
        Aurimas @moth4017 last edited by
        @moth4017 I have the same issue. Is your homing speed the same for Y and X in all of the files? I think it is CoreXY related only
        • moth4017
          ok this fixes the issue but i dont know why
          adding this to the end of homex
          G1 F12000 X155
          adding this to the end of Homey
          G1 F12000 Y155
            dc42 administrators @moth4017 last edited by dc42
            @moth4017 what I think is happening is that after homing X, the 'stalled' flag is still set in the driver that stalled first. In a CoreXY machine both X and Y motors are used for both X and Y moves, so that 'stalled' flag will cause the machine to think that Y is homed if you then try to home Y.
            The solution is: after homing X, move the head back in X a small amount to clear the stalled flag. Similarly when homing Y.
