    Converting the Duet WiFi to use an external antenna
    27
    10.6k
    • martinsundefined
      martins
      ESP-07S sold out in RS-online 🙂 how thats possible
      • S1lencerundefined
        S1lencer
        Hi, i have a problem since i changed the Module.
        I can only connect to the Duet Wifi in Accesspoint mode. If i change it to M552S1 it only says: Wifi reported error: no known networks found.
        The wifi is defenitly present.
        Did flash the right firmware files main as also the Wifiserver one.
        Running 1.21
        Anyone a clue why this could be?
        • S1lencerundefined
          S1lencer
          Got the Problem solved.
          David, i think the firmware 1.21 has a problem with loading the M587 with the Router data from the config.g to the remembered list.
          Got my problem solved with Repetier host, did send the M587 with ssid and password via g-code console.
            @S1lencer:
            How did you send the M587 command originally?
            • S1lencerundefined
              S1lencer
              Via the config script
                Sending M587 in config.g isn't going to work, because the wifi module doesn't get enabled until the end of running config.g. That's why I suggest using a macro to send those commands.
                • S1lencerundefined
                  S1lencer
                  Ok for the next time i will do that.
                  Should be mentioned in the Wiki.
                  • TheBasedDogeundefined TheBasedDoge referenced this topic
                  • infiniteloopundefined infiniteloop referenced this topic
