    Max Bed Level Compensation Z probe not triggered G32
    • ObiWan2Printundefined
      ObiWan2Print
      So using G32 after a successful homing of x, y, z the Railcore 2 300ZL results in the error message:
      "Z probe not triggered during probing move". However, I can see the BL Touch probe being triggered. What do I need to do to fix this error message? Also what commands control the speed of the Z-axis moving up during probing? Thanks
      my config files can be found here: https://forum.duet3d.com/topic/24328/bltouch-and-railcore-300zl-problems
      • fcwiltundefined
        fcwilt @ObiWan2Print
        @obiwan2print said in Max Bed Level Compensation Z probe not triggered G32:
        Has it ever worked?
        When the probe appears to function but the Duet does not respond it suggests the for some reason the signal from the BLTouch is not getting to the Duet.
        See below - the F and T parameters deal with speed:
          ObiWan2Print
          When I run the M280 P0 S90 the BLtouch retracts and vice versa with S10. Does this mean the probe is connected to the duet?
          • fcwiltundefined
            That means the probe is getting power and getting the signal from the Duet to deploy/retract - that is via the three wire connection.
            It does not mean the signal from the probe is getting to the Duet - that is the two wire connection.
            From your config file:
            M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02 H5 ; Bltouch probe type
            G31 X3.0 Y40.8 Z2.104 P25 ; Probe offsets
            In the M558 you have X, Y and Z parameters - that are obsolete and not used with v3 firmware. You also have H5 twice, once is enough.
            But you are missing the C parameter which specifies the input connection. The is likely the reason it is not working as desired.
              ObiWan2Print
              My current config files are different it turns out. How do I display them so I can paste them here? Also should I take out wifi info? From my current config.g file I have these lines:
              M558 P9 C"^zprobe.in" H5 R1 F50 T6000 A5 S0.02 ; RRF3 BLTouch connected to Z probe IN pin
              M950 S0 C"duex.pwm1" ; RRF3 Define BLTouch Servo (S0) on duet pwm1
              G31 X-4 Y-42 Z2.65 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
                ObiWan2Print
                My latest config.g :
                ; Configuration file for My Printer
                ; Communication and general
                M111 S0 ; Debug off
                M550 PRailCore ; Machine name and Netbios name (can be anything you like)
                ;M551 Pmyrap ; Machine password (used for FTP)
                ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEE ; MAC Address
                ;*** Wifi Networking
                M552 S1 ; Enable WiFi
                M555 P2 ; Set output to look like Marlin
                M575 P1 B57600 S1 ; Comms parameters for PanelDue
                G21 ; Work in millimetres
                ; Axis and motor configuration
                M669 K1 ; RRF3 change M667 to M669 ; set CoreXY mode
                M584 X0 Y1 Z5:6:7 E3:4:8:9 ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
                M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
                M569 P1 S0 ; Drive 1 goes backwards Y Stepper (Front)
                M569 P2 S1 ; Drive 2 goes forwards Unused
                M569 P3 S0 ; Drive 3 goes forwards Extruder
                M569 P4 S1 ; Drive 4 goes forwards Extruder (unused)
                M569 P5 S1 ; Drive 5 goes backwards Front Left Z
                M569 P6 S1 ; Drive 6 goes backwards Rear Left Z
                M569 P7 S1 ; Drive 7 goes backwards Right Z
                ;Leadscrew locations
                M671 X-10:-10:333 Y22.5:277.5:150 S2 ;Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
                M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping for axes& extruder, with interpolation
                ;RRF3 comment out: M574 X1 Y1 Z0 S1
                M574 X1 S1 P"xstop" ; RRF3 set X endstop to xstop port active high
                M574 Y1 S1 P"ystop" ; RRF3 set Y endstop to ystop port active high
                M906 X1400 Y1400 Z1000 E800 I60; Set motor currents (mA)
                M566 X600.00 Y600.00 Z200.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
                M201 X3000 Y3000 Z250 E1500 ; Accelerations (mm/s^2)
                M203 X24000 Y24000 Z900 E3600 ; Maximum speeds (mm/min)
                M208 X300 Y300 Z500 ; set axis maxima and high homing switch positions (adjust to suit your machine)
                M208 X0 Y0 Z-0.5 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
                M92 X200 Y200 Z1600 E837 ; steps/mm for x,y,z and extruder
                M906 X1280 Y1280 Z1220 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                ; Thermistors
                ;RRF3 comment out: M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                M308 S0 P"bedtemp" Y"thermistor" A"bed_heat" T100000 B3950 R4700 H0 L0 ;RRF3 Bed thermistor, connected to bedtemp on Duet2
                ;If you have a Slice Engineering thermistor, comment out the next line
                ;RRF3 comment out: M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                M308 S1 P"e0temp" Y"thermistor" A"Mosquit o_Magnum" T100000 B4725 R4700 C7.06e-8 H0 L0 ;RRF3 duet3 e3d
                ;If you have a Slice Engineering thermistor, uncomment the next lines. KITS DO NOT SHIP WITH A SLICE THERMISTOR - ONLY UNCOMMENT IF YOU ORDERED ONE
                ;M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T500000 B4723 R4700 C1.196220e-7 ;RRF3 slice thermistor
                M950 H0 C"bedheat" T0 ;RRF3 define Bed heater is on bedheat
                M140 H0 ;RRF3 define bed heater (Required in 3.1 or later)
                M950 H1 C"e0heat" T1 ;RRF3 define Hotend heater is on e0heat
                M307 H0 A240.3 C608.7 D8.2 S1.00 V24.1 B0 ; Bed Heaters
                M307 H1 A270.7 C90.4 D6.7 B0 S1.0 ;Heater 1 model
                M570 S360 ; Hot end may be a little slow to heat up so allow it 180 seconds
                M143 S285
                M950 F0 C"fan0" ;RRF3 define fan0
                M950 F1 C"fan1" ;RRF3 define fan1
                M950 F2 C"fan2" ;RRF3 define fan2
                M106 P0 H-1 ; disable thermostatic mode for fan 0
                M106 P1 H-1 ; disable thermostatic mode for fan 1
                M106 P2 H-1
                M106 P0 S0 ; turn off fans
                M106 P1 S0
                M106 P2 S0
                ; Tool definitions
                M563 P0 D0 H1 ; Define tool 0
                G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                ;*** If you have a single-nozzle build, comment the next 2 lines
                ;M563 P1 D1 H2 ; Define tool 1
                ;G10 P1 S0 R0 X0 Y17 ; Set tool 1 operating and standby temperatures
                ; Z probe and compensation definition
                ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
                ; IR PRobe - uncomment the following 2 lines if you have a and IR Probe, and comment out the BLTouch section below
                ;RRF3 IR Probe only comment out: M558 P1 X0 Y0 Z1 ; Z probe is an IR probe and is not used for homing any axes
                ;M558 P1 C"^zprobe.in" H5 F120 T6000 A5 S0.02 ; RRF3 IR Probe connected to Z probe IN pin
                ;G31 X0 Y30 Z2.00 P500 ; Set the zprobe height and threshold (put your own values here)
                ;BLTouch - comment out the following 3 lines if using a IR Probe
                ;RRF3 comment out: M307 H3 A-1 C-1 D-1
                ;RRF3 comment out: M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
                ;PanelDue
                T0 ; select first hot end
                • fcwiltundefined
                  Well that looks better.
                  If that is not working then I would check the wiring from the probe - as I recall it was a black and white pair of wires.
