    tools[N].fans[M] Object Model Property and M409 Mismatch
    Gcode meta commands
    • ronundefined
      ron
      I'm attempting to use the {tools[N].fans[M]} object model property selector to retrieve a fan number, but it appears to always evaluate to -1.
      4/22/2022, 2:27:45 PM: echo {tools[3].fans[0]}: -1
      4/22/2022, 2:27:50 PM: echo {tools[15].fans[0]}: -1
      Strangely, I do see the expected fan numbers when running M409 k"tools[N].fans[M]" and when viewing the entry in the Object Model plugin.
      4/22/2022, 2:28:00 PM: M409 k"tools[3].fans[0]": {"key":"tools[3].fans[0]","flags":"","result":0}
      4/22/2022, 2:28:05 PM: M409 k"tools[15].fans[0]": {"key":"tools[15].fans[0]","flags":"","result":2}
      This is on a Duet 3 MB6HC with three EXP3HC boards, all running RRF 3.4.0.
      Attempting to replicate the issue with RRF 3.3 also results in the -1 values with the object model property selector and the correct values when viewing the entry in the object model plugin, but when I try M409 I hit the firmware resetting bug that was fixed for RRF 3.4.0.
      Has anyone else run into this?
      • OwenDundefined
        OwenD
        Seems it might be an SBC and/or toolboard specific problem.
        Everything evaluates correctly on Duet 2 stand-alone
        ronundefined 1 Reply Last reply Reply Quote 0
        • ronundefined
          ron @OwenD
          @owend
          Thanks for the reply! I forgot to mention that this is a standalone setup. In my case, fan 2 is connected to the mainboard while fan 0 is connected to one of the expansion boards.
          oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • oliofundefined
            oliof @ron
            @ron I think it's the curly braces. Either put the echo inside or drop them.
              dc42 administrators @ron
              @ron I think you have found a bug, because I am getting similar results:
              24/04/2022, 11:43:30 	echo tools[1].fans[0]
              -1
              24/04/2022, 11:43:14 	m409 k"tools[1].fans[0]"
                  "key": "tools[1].fans[0]",
                  "flags": "",
                  "result": 0
              I will investigate this.
                dc42 administrators @dc42
                I have fixed this bug in the source code. The fix will be in release 3.5.0beta1 and also in 3.4.1 if we do one.
                ronundefined 1 Reply Last reply Reply Quote 1
                • ronundefined
                  ron @dc42
                  @dc42 Thank you! Glad to know it wasn't just a mistake on my end.
