    Duet 3 6hc mb with zyltech nema 23’s
    • jlee73undefined
      jlee73
      So I spent over 90 minutes on a face time call with Scott at zyltech. In a previous motor issues post I was having issues with the motors clunking. I reached out to Scott to see if he could help me with the wiring for the nema 23 that they sell.
      So it turns out that the Nema 23 from them has four wires red green blue and yellow. In order to match up with the 6HC motherboard which requires on drivers that the color order when you have the board in front of you and you have the drivers at the top. The duet board requires a different configurations. So after a lot of hard calculating and re-search this is what Scott came up with…
      If you are using Zyltech Nema 23 motors then with the drivers at the top when you are holding the board the color order from left to right is as follows… yellow, blue,green, red.
      B1= yellow
      B2= blue
      A1= green
      A2= red
      I hope that this helps others. And if you guys want exceptional customer service from a 3-D printing supplier then I cannot I hope that this helps others. And if you guys want exceptional customer service from a 3-D printing supplier then I HIGHLY RECOMMEND Zyltech.com for parts. They have a lot of things other stores don’t and they custom cut aluminum extrusion and lead screws. The woman who answers the phone named Crystal is awesome at finding the right person to help you 😃
      Www.zyltech.com
      1(832) 663-6568
      Tell them Justin sent you
        Regardless of motor we recommend identifying the motor phase pairs. Then as long as the pairs are wired side by side you're good to go.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting#identifying-the-stepper-motor-phases
