    Duet2 Eth/Duex5 2tacho readnig
    151
    • matej1006
      matej1006 last edited by matej1006
      Hello it's possible to read two tacho meter on DUET2 Etherne+Duex5
      one is from noctua fan other is from water cooling system
      LINK fot cooling tachometer 😉
      and if it's possible to show this two value on DWC or not?
      Part of code:
      ; Water colling NOCTUA FAN'S #########################################################################################
      M950 F1 C"!duex.fan7+exp.pb6" Q25000 							; fan 0 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector
      M106 P1 H5 I1 T20:25 L125 S1
      ; Water colling PUMP #################################################################################################
      M950 F2 C"!Fan0+exp.pb5" Q25000 ; fan 2 is a 4-wire PWM fan so invert it, use high PWM frequency
      M106 P2 H5 I1 T20:25 L255                                       ; set fan 2 value. Thermostatic control is turned on
      thanks for help
      • droftarts
        droftarts administrators @matej1006 last edited by
        @matej1006 See 'Connecting a 4-wire fan' tab here https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting#connecting-fans-to-duet-fan-pins
        Tacho wire (yellow or green): optionally, connect the tacho wire of a 4-wire fan to the cathode of a small signal diode (1N4148 should be OK) and connect the anode of the diode to any available digital input pin, to provide a reading of the fan RPM. For example, on Duet 2 WiFi/Ethenet connect it to pin PB6, and on Duet 2 Maestro use one of the four expansion pins.
        See the Duet 2 pinout for available digital input pins: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#inputoutput
        You should be able to use pretty much any pin with has 'Yes' or 'Input only' in the 'Input/Output' column.
        There is no 'exp.pb5' pin.
        matej1006 1 Reply Last reply Reply Quote 0
        • matej1006
          matej1006 @droftarts last edited by
          @droftarts
          Can i then connect pump to any other input on duex5 and change it to tacho input to gp 1-4 or not ?
          • droftarts
            @matej1006 I think that should work. See the DueX list of pin names and capabilities here https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#inputoutput
            • matej1006
              @droftarts
              can you help me why i get 1500RPM and i got this code
              M308 S5 P"e0temp" Y"thermistor" T10000 B10000 C7.06e-8 A"Water temp." ; define E0 temperature sensor sensor 5 as thermistor on pin e0temp water temp.
              M106 P1 H5 T23:25                                           ; set fan 0 value. Thermostatic control is turned on
              e0temp as i read is 22.5 then fan must be off and not turn at 1500 rpm
              do i need any resistor between 5v and PWM signal or something like that?
              Please help thanks
              droftarts matej1006 2 Replies Last reply Reply Quote 0
              • droftarts
                @matej1006 Did you add the diode? I believe it is required on Duet 2:
                • matej1006
                  matej1006 @matej1006 last edited by
                  @matej1006 yes i added diode
                  • droftarts
                    @matej1006 The example on the fans page shows exp.pb6 with pullup resistor ^ enabled. Not sure if that is needed:
                    : 4-wire PWM fan and tacho
                    M950 F2 C"!fan2+^pb6" ; Fan 2 uses the Fan2 output, but we are using a PWM fan so the output needs to be inverted, also we are using PB6 as a tacho input with pullup resistor enabled
                    Can you manually control the fan correctly? Send M106 P1 H-1 to turn off thermostatic control, then M106 P1 S0 to turn the fan off and M106 P1 S255 to turn it on. If it is inverted, remove ! from M950 command.
                    • matej1006
                      @droftarts @droftarts i run at full speed 255 and it's show 1500 rpm or i run at 125 and is same 1500 rpm
                      • droftarts
                        @matej1006 Difficult to say what is going wrong. It's possible connecting it to the DueX is the issue (maybe latency?), in which case connect the tacho wire direct to a pin on the Duet. It's also possible that the fan tacho doesn't comply with the specification for tacho wires that RRF uses.
                        matej1006 1 Reply Last reply Reply Quote 1
                        • matej1006
                          @droftarts @dc42
                          I have connected my flow sensor like that and show always 0
                          1 GND commom for all voltages
                          2 5V external power supply
                          3 signal connected duex.gp4
                          ; Water colling PUMP #############################################################################################################
                          M950 F2 C"Fan0+^duex.gp4" Q25000                     ; fan 2 is a 4-wire PWM fan so invert it, use high PWM frequency
