Pressure advance weird behaviour in 3.4
Can you check whether a particular input is set to relative or absolute extrusion by looking in the 'inputs' section of the OM? This way we could see if it's getting set correctly at startup and how it changes or not when the print is started with or without your change to the start gcode.
@phaedrux What input are you interested in? I have from 0 to 11, and under name of each one of them none says "extruder"
