Maybe Bug: Print started with cold hotend
  • undefined
    dgrat
    I noticed at least one time with firmware 3.4 that a print started with cold hotend.
    So the heating failed for some reason and then the print started.
    This happened after starting a print after breaking an old one.
    ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 09 2019 20:31:57 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"Ender" ; set printer name
    ; Panel Due
    M575 P1 S1 B57600
    M667 S0 ; select Cartesian mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P2 S0 ; physical drive 2 goes forwards
    M92 X80 Y80 Z3200 E830 ; set steps per mm
    M566 X1200 Y1200 Z120 E3000 ; set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z600 E450 ; set maximum speeds (mm/min)
    M201 X1200 Y1200 Z120 E3000 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z800 E630 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X225 Y225 Z220 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; Set active high and disabled endstops
    M574 Y1 S1 P"ystop" ; Set active high and disabled endstops
    M574 Z2 S1 P"zstop" ; Set active high and disabled endstops
    ; Disable heaters H3-H7 to free up pins
    M950 H3 C"nil"
    M950 H4 C"nil"
    M950 H5 C"nil"
    M950 H6 C"nil"
    M950 H7 C"nil"
    M558 P9 C"^zprobe.in" H8 F100 T6000 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-25.5 Y37 Z1.95 ; Set Z probe trigger value, offset and trigger height Z / before trigger: 1.7
    M557 X40:220 Y00:180 S60 ; Define mesh grid
    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
    M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
    M307 H0 S1.00 V23.9
    M140 H0
    M308 S1 P"e0_temp" Y"pt1000"
    M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
    M143 H1 S265 ; Set temperature limit for heater 1 to 240C
    M307 H1 A271.1 C122.4 D24.0 S0.25 V24 B0 ; limit the hotend heater to 25% power
    M950 F0 C"fan0" Q500
    M106 P0 S0.0 I0 H-1 C"Print Fan" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M950 F1 C"fan1" Q500
    M106 P1 T50 H1 C"Hotend Fan" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M950 F2 C"fan2" Q500
    M106 P2 T50 H1 C"Case Fan" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ; enable: config-override.g
    M501
    ? 1 Reply Last reply 1 May 2022, 12:35 Reply Quote 0
      A Former User @dgrat
      This post is deleted!
      undefined 1 Reply Last reply 2 May 2022, 08:02 Reply Quote 0
      • undefined
        oliof
        you may need to select the Tool T0 again after interrupting a print so it's selected at start of a new print.
        undefined 1 Reply Last reply 2 May 2022, 08:03 Reply Quote 0
        • undefined
          dgrat @A Former User
          @arnold_r_clark
          Cura 4.13
          • undefined
            dgrat @oliof
            @oliof
            I'll check that
            1 out of 5
