    Solved J type thermocouple syntax error
    Gcode meta commands
    • aronmeszaros
      aronmeszaros last edited by
      Hello, I would like to configure a J type thermocouple with the following command: M308 S8 P"1.spi.cs0" Y"thermocouple-max31856" T"J" A"Nozzle" . It throws the following error: M308: expected number after 'T'
      Type K works just fine I have 3 of them working. The TC boards are on an expansion board thats why the 1.spi
      Im running: RepRapFirmware for Duet 3 MB6HC version 3.4.0beta6 (2021-11-06 11:38:57) running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Im afraid to upgrade because there were a lot of things that were not working after this update and this version had the combination where it all did
      aronmeszaros 1 Reply Last reply Reply Quote 0
      • aronmeszaros
        aronmeszaros @aronmeszaros last edited by
        @aronmeszaros is there something wrong with my syntax or it could be because of the firmware version?
        jay_s_uk dc42 2 Replies Last reply Reply Quote 0
        • jay_s_uk
          jay_s_uk @aronmeszaros last edited by
          @aronmeszaros upgrade to 3.4 stable
            dc42 administrators @aronmeszaros last edited by
            @aronmeszaros there was an error in the documentation. The thermistor type letter parameter is K not T. I have corrected the documentation.
            However, you should upgrade to 3.4.0 stable.
            aronmeszaros 2 Replies Last reply Reply Quote 1
            • aronmeszaros
              aronmeszaros @dc42 last edited by
              @dc42 thank you, I’ll give it a try today
              • aronmeszaros
                @dc42 Thank you! The K"J" parameter did the trick, it works prefectly 😄
                I saw it was also changed in the documentation 🙂
                I noticed one more place (in the new docs) where it could be changed, Im sending the picture and link: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_thermocouples
                Otherwise we can mark this topic as solved
                Thank you again
                dc42 1 Reply Last reply Reply Quote 1
                  @aronmeszaros thanks for pointing that out. I've corrected it.
                  • Topic has been marked as a question  dc42 dc42
                  • Topic has been marked as solved  dc42 dc42
