    PID problems
    315
    • BlitzReg
      BlitzReg last edited by
      HI, I'm running firm ware 3.4.0 and trying to do a bed PID of M303 H0 S80. But it gets to phase 3 and just runs for hours not doing anything. I used a thermal gun on top of the bed and it shows 91C and the duet panel is showing 75C. I tried the new M303 T0 S80 but says no heater started. Not sure what the problem is. If the bed temp is wacky then probably my hemera extruder. This is a new hypercube build and the prints are not coming out very good quality. I'm thinking that true temperatures are not running. Please help! Larry
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 27 2022 07:58:07 GMT-0800 (Pacific Standard Time)
      M550 P"EVO2" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S1 ; phys4cal drive 2 goes backwards
      M569 P3 S0 ; physical drive 3 goes forwards
      ;M92 X81.41 Y81.41 Z394.7 E400 ; set steps per mm
      M92 X79.85 Y79.85 Z400.04 E392.47 ; set steps per mm
      M566 X900.00 Y900.00 Z12 E300 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z3000.00 E1000.00 ; set maximum speeds (mm/min)
      M201 X300 Y300 Z250 E1500 ; set accelerations (mm/s^2)
      M906 X850 Y850 Z650 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Axis Limit
      M208 X0 Y0 Z-10.0 S1 ; set axis minima
      M208 X250 Y260 Z180 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      ;M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
      ;M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F500 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X7 Y-50 Z2.675 ; set Z probe trigger value, offset and trigger height
      M557 X30:250 Y15:210 S20 ; define mesh grid
      ;BLTouch Heater
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp
      M912 P0 S-12.6
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @BlitzReg last edited by
        @blitzreg Make sure you have the correct B value for your bed thermister and check if it's getting the full voltage if it's a DC bed.
        To use M303 T0 S80, which tunes T0, you need to select T0. It's recommended to put a T0 at the end of the config.g, so a tool is selected on start up.
        BlitzReg 4 Replies Last reply Reply Quote 0
        • BlitzReg
          BlitzReg @Stephen6309 last edited by
          @stephen6309 How do I know the B value my resister? For some reason when I try the M303 T0 S80 the extruder starts to tune instead of the bed and on the duet panel the extruder is showing T0.
          • BlitzReg
            @stephen6309 yes its a 24V bed
            • BlitzReg
              @stephen6309 I'm getting 24.2v from the PSU and I'm reading 23.4V on the heat bed side of the mosfet.
              • BlitzReg
                @stephen6309 I'm reading 23.66V on the bed connector on the duet wifi 2 board going to the mosfet
                  Phaedrux Moderator @BlitzReg last edited by
                  @blitzreg said in PID problems:
                  M303 T0 S80 is to tune the tool heater as a tool including the associated fan.
                  M303 H0 is correct for tuning heater 0 which you have assigned as the bed heater.
                  Can you send M122 and M98 P"config.g" in the gcode console and post the results here?
                  So you are using an external mosfet for the bed heater?
                  What does the temp graph look like during the tuning process? Can you snap a screen shot?
                  B4138
                  If your bed thermistor is bog standard the B value is probably 3950 instead.
                  BlitzReg 7 Replies Last reply Reply Quote 0
                  • BlitzReg
                    BlitzReg @Phaedrux last edited by
                    @phaedrux Hi, ok I'll try that! This is my 2nd hypercube I have built and both have the same thermistor and bed in them. The first one has firmware 1.21 and M303 H0 S90 works good. Both machines are setup identical except firm ware version difference. Bellow is the working printers config.g
                    • BlitzReg
                      @phaedrux
                      m122
                      5/5/2022, 2:20:12 PM m122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
                      Board ID: 08DJM-9178L-L2MS8-6J1FL-3S06N-KBHGP
                      Used output buffers: 3 of 24 (13 max)
                      Static ram: 23868
                      Dynamic ram: 74568 of which 40 recycled
                      Never used RAM 13604, free system stack 184 words
                      Tasks: NETWORK(ready,13.1%,236) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,86.8%,440) IDLE(ready,0.0%,30), total 100.0%
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 01:05:34 ago, cause: software
                      Last software reset at 2022-05-05 13:14, reason: User, GCodes spinning, available RAM 13604, slot 0
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Step timer max interval 0
                      MCU temperature: min 21.9, current 23.6, max 24.0
                      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                      Events: 0 queued, 0 completed
                      Driver 0: standstill, SG min n/a
                      Driver 1: standstill, SG min n/a
                      Driver 2: standstill, SG min n/a
                      Driver 3: standstill, SG min n/a
                      Driver 4: standstill, SG min n/a
                      Driver 5:
                      Driver 6:
                      Driver 7:
                      Driver 8:
                      Driver 9:
                      Driver 10:
                      Driver 11:
                      Date/time: 2022-05-05 14:20:10
                      Slowest loop: 4.93ms; fastest: 0.18ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 3.6ms, write time 0.0ms, max retries 0
                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      === AuxDDARing ===
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty
                      === Network ===
                      Slowest loop: 15.75ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        WiFi firmware version 1.26
                        WiFi MAC address 84:0d:8e:b2:1e:40
                        WiFi Vcc 3.42, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25976
                        WiFi IP address 192.168.86.101
                        WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                      • BlitzReg
                        @phaedrux said in PID problems:
                        M98 P"config.g"
                        5/5/2022, 2:21:34 PM M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Error: Heater 7 not found
                        • BlitzReg
                          @phaedrux yes external mosfet
                          • BlitzReg
                            @phaedrux I'm running pid tune now on the bed. The bed with a IR gun is 10C higher then what the thermistor is showing
                            • BlitzReg
                              @phaedrux
                              • BlitzReg
                                Yes, just looked up what I purchased and they are 3950. So , do I put B3950 ?
                                  Yes.
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950
                                  BlitzReg 2 Replies Last reply Reply Quote 0
                                  • BlitzReg
                                    BlitzReg @Phaedrux last edited by BlitzReg
                                    @phaedrux hi so no C0 R4700 behind B3950? I'm running it now
                                    • BlitzReg
                                      @phaedrux right now the thermistor in phase 3 reads 84 and the IR gun shows 96. Makes me wonder if the thermistor is bad
                                        Where is the thermistor positioned to get the reading?
                                        Are you measuring with the IR temp gun in the same location?
                                        • BlitzReg
                                          @phaedrux no, I actually testing it all 4 corners and in the middle where the thermistor is located
                                          • BlitzReg
                                            @phaedrux Almost 1 hour on phase 3. My other hypercube has already tuned using firm ware 1.21. now I'm wondering when I tell the extruder to heat to 220C its actually 220C. My first prints off them looked like they got pretty hot. I am using the e3d hemeria w/volcano direct drive. I also have their REVO
                                              For the hotend you have a known thermistor and the correct values from E3D, so it should be as accurate as you can expect.
                                              As for the bed, at 24v it takes a long time to heat up and it does many cycles, so it can take quite a while. Rather than tuning to 90c, try a more reachable temp like 60.
                                              BlitzReg 3 Replies Last reply Reply Quote 0
                                              • BlitzReg
                                                @phaedrux Hi, the problem was the thermistor in the bed. I swapped it out and now the temps are almost the same between the panel and the IR Gun. Now the gremlin has move to the extruder. I have a REVO Hermera direct drive and it keeps getting heater faults. I have ver 3.4.0 and ran M303 T0 S240 and it tunes fine. But I noticed the the temp rises above the print temperature I set and keeps going until there is a heater fault.
                                                • BlitzReg
                                                  • BlitzReg
                                                    @phaedrux Why is it saying Heater 0 when the fault happens on heater 1 the extruder? Not sure what is happening here!
                                                      I think that is a bug in the displayed heater. Please update to 3.4.1 RC1
                                                      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.1rc1
                                                      What did your tuned values result in?
                                                      If the part cooling fan doesn't have a big impact on the heater, you can tune the hotend as a normal heater with M303 H1 S240 and see if it behaves better.
