    Music in my PanelDue 5i with Duet2 Ethernet and reprap 3.4.1
    PanelDue
    • hareshPrajapati
      hareshPrajapati last edited by
      I found post related to my topic
      https://forum.duet3d.com/topic/15722/turn-your-printer-into-a-juke-box
      I tried given steps in the link to generate music using M300 Command But somehow
      my panleDue 5i didn't playing music tones properly .
      I am using duet2 ethernet board connected with panelDue 5i with latest version 3.4.1
      Is that any way to generate proper Gcode file for my problem??
        What exactly happen when you try?
        hareshPrajapati 1 Reply Last reply Reply Quote 0
        • hareshPrajapati
          hareshPrajapati @Phaedrux last edited by hareshPrajapati
          @phaedrux when I try I didn't
          get musical tone
          First I try simple mario.g ringtone but buzzer only beep , it didn't produce what exactly i send.
          I think tools are not producing correct Gcodes for reprap 3.4.1
          look at my mario.g file and recording files of music
          recording
          mariotune.g
            I see. I haven't really tested it recently.
            The command stream is quite dense with those files. Lots of commands in a short amount of time. You could experiment with increasing the baud rate on the PanelDue and in the PanelDue command in config.g to match.
            • hareshPrajapati
              @phaedrux
              I changed baud rate to 115200 on the PanelDue and also in PanelDue command in config.g but same results !!!
                What firmware do you have loaded on the PanelDue?
                • hareshPrajapati
                  @phaedrux PanelDue 3.4.0 (latest)
                  Reprap (latest)
