    Using different config.g files?
    Duet Web Control
    • Nightowlundefined
      Nightowl
      Is it possible to have different configurations for the same machine?
      This is more about changing the working limits for each tool of the CNC machine rather than changing the physical hardware configuration, but I was wondering if separate configurations could be used when using a milling motor, a laser or a drag knife, for example.
      Thanks
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      OwenDundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Nightowl
        @nightowl999
        Have a look at M505
        • deckingmanundefined
          deckingman @Nightowl
          @nightowl999 Yes it most certainly is possible and as @OwenD has said, take a look at M505. Essentially it changes the "sys" path. So not only can you have separate config.g files, your can use different system macro such as homing, pause, resume etc.
          My "root" config.g looks like this
          ; Configuration file for Duet Gen 3
          ; ******CHOOSE .SYS PATH ******
          M505 P"6InputMultiMat"
          ;M505 P"6InputMixing"
          ;M505 P"SingleInput"
          ;M505 P"2Input"
          M98 P"config.g"
          So to change between configurations, I simply uncomment the one that I want to use and comment out all the others.
          • Nightowlundefined
            Nightowl
            Well, that looks pretty good!
            I was also wondering, as I've got a browser link to DWC, whether or not I could use a shortcut to achieve the same sort of thing, e.g. Name_Laser, Name_CNC, etc?
            Or maybe even a prompt, asking which 'mode' I want to use, perhaps.
            MintyTreborundefined 1 Reply Last reply Reply Quote 0
            • MintyTreborundefined
              MintyTrebor @Nightowl
              @nightowl999 You could create Macros to easily switch or use BtnCmd to create something like this:
              each button runs the appropriate M505 cmd.
              NodeDSF - Native Node-Red integration with Duet boards.
              BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
              ReleaseMgr - Duet update info inside DWC.
              Repo
              Nightowlundefined 1 Reply Last reply Reply Quote 2
              • Nightowlundefined
                Nightowl @MintyTrebor
                Thanks, @mintytrebor. I'm looking at your BtnCmd already, but I never thought to add macros as you've suggested.
                Thank you 👍
