    MBLA, not getting it right.
    • RogerLundefined
      RogerL
      I been reading instructions on how to configure manual bed leveling assistant but I cannot get it to work correctly.
      I have a carthesian printer and four corner screws to adjust my table.
      Can get it to probe using G32 and it does all my four corners but resports back a error:
      G32
      Error: Number of calibration factors (3) not equal to number of leadscrews (4)
      I been trying to figure out how to set this but no luck.
      Here are my Bed.g lines
      G28 ; home
      G30 P0 X0 Y0 Z-99999 ; probe near an adjusting screw
      G30 P1 X350 Y0 Z-99999 ; probe near an adjusting screw
      G30 P2 X350 Y223 Z-99999 ; probe near an adjusting screw
      G30 P4 X0 Y223 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
      Here is my config.g lines
      M671 X-15:350:350:-15 Y-12:-12:250:250 P1.0 ;
      Any ideas what I do wrong?
      • fcwiltundefined
        fcwilt @RogerL
        @rogerl
        See that S3 at the end of the last G30?
        That number has to match the number of G30 commands.
        So change S3 to S4.
          @rogerl as @fcwilt says, also change P4 to P3.
          • RogerLundefined
            RogerL
            That worked but I got a new error
            G32
            Error: Bed calibration : 4 factor calibration requested but only 3 points provided
            • RogerLundefined
              RogerL
              All good now with both changes, thank you
