    IR sensor to toolboard with RFF configurator?
    • 57buickundefined
      57buick
      Im trying to configure the setup with the online configurator to use my IR sensor with a new toolboard 1LC and it does not seem to allow me to select the pins I need on the toolboard? Is the online configurator not working for that yet?
      Can someone explain what commands I need in the config to do it manually?
        Have you added a toolboard in the config tool? On the i/o mapping page at the top you can add an expansion board and it's pins will then become mappable in the drop downs. Does that help?
